I will ship these items to any location, buyer pays shipping. If you’re local to Clarksville, TN, then I’m fine with in-person pickups also. If you need additional photos or info, just let me know. The link below each item description is to the photos. Thanks!
351C heads. Top casting: 9170. Bottom casting: 2 D1AE CB Ford. Tag: 351C 71-3 L24 K614J. These heads are from 71-74 fords and are 2V. They are assembled with valvetrain and are in need of a rebuild. $50 OBO.
https://picasaweb.google.com/110776104127009924462/6470MustangParts?authuser=0&feat=directlink
93 Mustang 5.0 302 HO stamped steer rocker set. These are the stock pedestal rockers that came on a 93 5.0 and they are used. The set is not complete but would be good if you needed replacement parts. I have 16/16 arms, 14/16 bolts, 16/16 fulcrums, and 15/16 L retaining brackets. $20 OBO.
https://picasaweb.google.com/110776104127009924462/50Parts?authuser=0&feat=directlink
93 Mustang 5.0 engine parts. Includes serpentine crank pulley D9ZE-6312-A7B (6” diameter) and 4.5” diameter underdrive pulley, tensioner, AC delete pulley, alternator pulley, fan spacer, timing cover, and stock used harmonic damper. Also includes the following 93 5.0 parts: new egr valve, new fram fuel filter, and used oil pan support rails. $50 OBO.
93 Mustang 5.0 valve covers. Polished and includes metal gaskets. $45 OBO.
Ford Racing 5.0 spark plug wire set. Model M-12259-C301. Fits 5.0 & 5.8L engines. Blue wire color. 9.0mm wires with 45 degree boot into the spark plugs. New in box and unused. $25 OBO.
Powerforce harmonic damper spacer. Model 81008. NEW. Crankshaft Pulley, 0.875 in. Thick, Aluminum, Ford 302/351W, 4-Bolt. $15 OBO.
Autoloc SVPRO5, 8-Channel remotes, 50Lbs solenoids, Remote Shaved Door Kit. This is the top model Autoloc kit with the strongest solenoids to open the heaviest of doors. New and still sealed in plastic. $300 new. $125 OBO.
https://picasaweb.google.com/110776104127009924462/OtherParts?authuser=0&feat=directlink
