T5 Conversion
unrealmach1
89
Detroit, MI
I have a 69 mustang I want to convert from an Auto to a T5-z that I have, but I have a question. I was told that their should be a knockout stamped where the clutch rod need to be located, but I don't see one. Anyone done this conversion? ANy one have pic of where the rod comes through the firewall? I have a JMC Hyd. CLutch kit I want to use, just need to find where to mount it on the firewall. THanks.
:bang:
I did the same thing. I also could not find the knockout for the rod. There is actually a perfect place to mount the JMC kit on our cars. I have pics and I will post them up either tonight or tomorrow I have work and will be busy. I remember taking some good pictures so it should help you out, I will also give you pics of how it was done up inside the car.
If you could post them or email them to me that would be great. Thanks for the help.
:SNSign:
just wondering if you had a chance to find the pics? Thanks.
There we go use these with the link I gave you I hope they help they were the best ones I took. If you use the picture from the inside as a template you should have no clearance issues with the master cyliner and brake booster.
shotsy said:
I am thinking about doing the T5 swap on my coupe as the C4 revs to high @ 75 MPH im taching 3000 rpm with 3.00 gears in the rear. What can I use for a donor car? Any info advice would be great
Shotsy the late model 5.0's would be the ones you would want to use as a donor. I strongly advise against it though, with your clevaland you will want to at the very least use a t-5Z. I don't believe in buying used stuff unless you have all the expertise to rebuild it.
