Is it possible to change just the 5th gears from one t-5 into another...I had a t-5 with the 2.95 1st gear, hardened countershaft, and the .059 5th gear overdrive which is VERY low as in at 2200rpms I was doing 80mph.......Well I blew 5 teeth off the 3rd gear part of the countershaft out of that trans...I got a bone stock t-5 from my friend which is in my car now and the 5th gear SUCKS in it...Im at 3,000rpms at about 75mph...Im driving a 14 hour drive soon so I was planning on taking the 2 5th gear gears out of that trans (which i already have out) and swap it into the trans in my car now, do u guys see anything wrong with that? only thing that holds them on is the 2 clips, I just want to know if theres any special things I dont know about before I take the trans out of my trans now and swap the gears out. Thanks
only thing I can think of is changing the rear gears?, which im not sure to go to since mine seems so steep but is supposedly 373s....is it possible to actually get a different ratio 5th gears so I can swap them out and be done with it without messing with all my other gears? Any advice would be greatly appreciated
