  • 1994 - 1995 Specific Tech
T5 from fox
  • Thread starter Thread starter 95snoozer
  • Start date Start date Apr 11, 2006
1 of 2 Next Last
95snoozer
2,572
RCR
Apr 11, 2006
  • Apr 11, 2006
What differences if any are there? As long as I am using my Bellhousing and cross member, I thought everything was the same, but the guy i want to buy a beefed up one from says he thinks they are different
1slow95
1,797
ohio
Apr 11, 2006
  • Apr 11, 2006
The input shaft is shorter on the fox t-5's, so you need to use their bellhousing or install a longer input shaft. Even with the fox bellhousing, it should still bolt up to your crossmember. You will need a driveshaft spacer, or a longer driveshaft tho with the fox bell.
illwood
636
Worcester, MA
Apr 11, 2006
  • Apr 11, 2006
I believe the input shaft is a different length.
illwood
636
Worcester, MA
Apr 11, 2006
  • Apr 11, 2006
Looks like Low-5.0 beat me to the "post" button.
95snoozer
2,572
RCR
Apr 11, 2006
  • Apr 11, 2006
crap, i need a different t5 to make the trip. It sucks that i am going to haev to pull this one and replace the tail shaft bushing and the rear seal just to possibly replace it in a few months.
The tail shaft might be bent they are guessing... heck if i know, but it vibrated like crazy 70 and up.
1slow95
1,797
ohio
Apr 11, 2006
  • Apr 11, 2006
Couldn't you just install your old input shaft on the fox t-5? AFIK, that should work...
84convertablegt
589
Columbus, OH
Apr 11, 2006
  • Apr 11, 2006
not to steal the thread in any way, but if the only difference is the input shaft, which i believe it is, then how do you change the input shaft? must be kinda difficult or everyone would'nt be changing bellhousings and buying the driveshaft spacers, theyd just swap input shafts.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Apr 11, 2006
  • Apr 11, 2006
No because the fox T5 is shorter physiclly(sp?) so everything moves forward. Putting a shorter input shaft into a longer tranny wont work. The bell housing (fox) must be used when you do the switch. BTW the sn95 t5 input shaft is 5/8 longer.
95Vert
1,785
North Mexico (deep south Texas)
Apr 11, 2006
  • Apr 11, 2006
The tranny I'm usingis off an 89fox. It's a t-5 and everything had to be used off of an 89. To my surprise, my old driveshaft worked fine. The one problem I did see was that the guy whom did the swap had to weld a small plate to the front of the crossmember to bolt the tranny mount to. It is physically shorter than our year but it will work.
mytight95
2,605
Dothan,Al
Apr 11, 2006
#10
  • Apr 11, 2006
  • #10
95vert i had a 93 t5 in mine when i bought it, it lined up with the crossmember, and the mount fine. I have since put a 95 cobra tranny, 95 bell and clutch fork in though... everything still lined up fine..... sounds weird, was your an original auto car?
jason
95Vert
1,785
Apr 11, 2006
#11
  • Apr 11, 2006
  • #11
Yep, it was an auto.
Killercanary
The car that set the bar.
Altoona, PA
Apr 11, 2006
#12
  • Apr 11, 2006
  • #12
Snoozer, I bent thre mainshafts in my T5 before I finally said screw it and went with the TKO. It'd vibrate so bad that it'd make the palm of my hand itch.
1slow95
1,797
ohio
Apr 11, 2006
#13
  • Apr 11, 2006
  • #13
What I've heard is just the input shaft is shorter on the fox's, and the bellhousing has to be shorter for the shorter input shaft. I've never heard anything about the physical size of the transmission itself being any different than the SN95's.
To anybody that's rebuilt a t5, what do you need to do to remove the input shaft? I took my old one apart, but I can't remember how I removed the input shaft.
95Vert
1,785
Apr 11, 2006
#14
  • Apr 11, 2006
  • #14
I noticed that too. It sucks, it so annoying. I can't wait to get some cash together and just do the Tremec swap.
95Vert
1,785
Apr 11, 2006
#15
  • Apr 11, 2006
  • #15
Think about it, if the bellhousing is shorter, that eats up some length from the overall size of the tranny.
1slow95
1,797
ohio
Apr 11, 2006
#16
  • Apr 11, 2006
  • #16
Yeah, but what happens if you put the longer bell on there? It should be the exact same length as the SN95 t5 then.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Apr 11, 2006
#17
  • Apr 11, 2006
  • #17
Correct low..
94-302-vert
1,947
NE CT
Apr 11, 2006
#18
  • Apr 11, 2006
  • #18
Paul, tell me more about this vibration... worse at speed but you could really feel it in the shifter? Any gear worse than the others?
mricci
301
Massachusetts
Apr 11, 2006
#19
  • Apr 11, 2006
  • #19
I am in the process of doing a t-5 swap and i was told you dont need the spacer but for the angles to be right and the driveshaft to be fully in the tranny correctly you need the spacer. That if you dont it can cause problems down the line. Im not postitive about that but just figured i would put out there what i was told. Some people talk about it in the tremec threads if you read up on some of them.
95Vert
1,785
Apr 11, 2006
#20
  • Apr 11, 2006
  • #20
You're right there, but I thought you meant if you used the shorter bell. keep in mind that you would have to switch out the input shaft.
mricci, I just spoke to another guy who did the fox tranny swap and he's not running a spacer on his car and also had to weld that plate to the crossmember. FWIW, he's got a 331 stroker.
1 of 2 Next Last
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T5 identification
  • 3054tony
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
AeroCoupe
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
F
T5 transmission questions
  • Forddestroyer96
  • Aug 27, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 27, 2025
Forddestroyer96
F
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
