t5 help
  • Thread starter Thread starter Foxfan88
  • Start date Start date Oct 6, 2005
1 of 2 Next Last
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Oct 6, 2005
  • Oct 6, 2005
ok tranny is sitting on a table.
You know how you can put it in gear and the input shaft will be easier/harder to turn.
like 1st will be easier and 2 will be a tad harder, then 5th will be hardest to turn.
well i was spinning it today to check it and i noticed that reverse is harder to turn.... its about the same ratio as first so it should be as easy right???
mines like as hard to turn as 5th gear pretty much...
also i noticed somtimes it would make grinding noises when i turned it sometimes in reverse, then i just put it out and back into gear and it went away...
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Oct 6, 2005
  • Oct 6, 2005
Maybe a synchro is on its way out?
88gt
794
Drillers cabin
Oct 7, 2005
  • Oct 7, 2005
you may have some trash/dirt in the case..
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Oct 7, 2005
  • Oct 7, 2005
well its empty of fluid now.... maybe adding fluid could help???
BERT306
75
  • Oct 8, 2005
Maybe one of your dumb questions got lodged in the 5th/reverse slider? just a guess though
rd
3,316
63
109
Ocean Springs MS
Oct 8, 2005
  • Oct 8, 2005
Are you trying to fix a problem you had when it was in the car, or just rebuilding?
The gears will take different amouts of effort to turn because the ratios are different, etc.
Reverse turns the input shaft, the entire countershaft, as well as the idler gear and shaft for reverse, as well as the entire output shaft, so its got a lot of stuff to turn.
Cant say what is making noise or grinding, but checking for above limits play or wear should find it. The shift fork wear and alignment may have some affect on this.
Euphoric306
905
  • Oct 8, 2005
reverse is harder to turn because in first gear you're turning the input shaft which turns the countershaft which turns a gear on the output shaft... in reverse you're turning the input shaft that turns the countershaft that turns a reverse counter gear that turns a gear on the output shaft... dont worry about it bub cuz how often will you be in reverse anyway if there really is something wrong (doubtful)
adding fluid and having a 225hp engine turn the shaft (instead of a 1/50 hp human hand) will definitely help with that problem...
the grinding you hear in reverse is the straight-cut gears meshing and turning, when it was open did you notice some straight cut gears and then all the rest are spiral cut right... that sprial cut helps eliminate that noise your hear and actually makes the gears stronger too
... when you're going in reverse you hear a whining noise, which is the gear noise from straight cut gears... imagine in older cars where every gear in the tranny was straight cut... oh god the horror
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Oct 8, 2005
  • Oct 8, 2005
thanks for the help it answered my questions
my t5 was fine according to your posts, but before i read this i TOOK IT APART!!!!!!!!!
stupid me. but its like the 5 billionth time i've dont it so it wont be a problem....
once again thanks!
oh an my little noise was from not being all the way in R so....
forgot something....
did any of you guys have problems with the frontmost syncro sleeve (on top)
sliding fowards?? mine done it a couple of times, its a PITA since i have to push all 3 of the little insert before it will slide back....
dkins419
187
Michigan
Oct 8, 2005
  • Oct 8, 2005
dont you have to put it in 5th gear then reverse? This is what i have always been told because reverse doesnt have a syncro. If i put it in reverse it will grind then go in but if i put it in 5th gear then reverse its fine. This is with my old and new t-5.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Oct 8, 2005
#10
  • Oct 8, 2005
  • #10
mine goes into reverse by itself ok, sometimes it might grind but if i make sure its all the way engaged its alright.
i just got back from putting it back together ( getting good at it lol)
i went and bought some gear oil and flushed the tranny good and used some grey gasket maker and it feels good now.....
also whats the correct fluid to put in it???
its an 89 t5 if it matter, they guy at oreilys told me dexron mercon auto tranny fluid, i was like .
sunil6784
620
Boston, MA
Oct 8, 2005
#11
  • Oct 8, 2005
  • #11
Yup...ATF Dexron III
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Oct 9, 2005
#12
  • Oct 9, 2005
  • #12
really i tried some on it and its HELLA THICK compared to what drained out.....
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 9, 2005
#13
  • Oct 9, 2005
  • #13
When new, a T-5 should have no problems slipping into Reverse on it's own. If it doesn't go, you should slip it into a forward gear and then try for reverse.
I don't recommend using 5th gear because the 5th gear synchro is a weak brass. Using it like this could put wear on it. I would use 4th gear because it's not uses as much as the other 3 gears and it has a more durable synchro.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 9, 2005
#14
  • Oct 9, 2005
  • #14
I have a couple T-5 sitting around and I just tried spinning the shaft by hand
1st gear is the easiest by far.
Reverse is a little harder than 1st but easier than 2nd gear.
If you spin the opposite way by spinning the output shaft, then 5th is the easiest to turn and reverse and 1st is the hardest.....that's why you always park a 5-spd in R or 1st gear and never anything higher.
Euphoric306
905
#15
  • Oct 10, 2005
  • #15
good point 5L5 about using 4th instead of 5th, and about parking in 1st or 5th
foxfan are you sure you're using the right fluid? if its that much thicker than what came out, your old tranny fluid must have been HELLA OLD, because new ATF is pretty thin. do not put 80W gear oil in your t5, please.
maverick0716
3,924
Chilliwack, BC, Canada
Oct 10, 2005
#16
  • Oct 10, 2005
  • #16
Reverse actually doesn't have synchros
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Oct 10, 2005
#17
  • Oct 10, 2005
  • #17
i used gear oil to flush it of crap that fell inside. it has nothing in it now...
the old fluid was red, like ATF but very thin...
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 10, 2005
#18
  • Oct 10, 2005
  • #18
Foxfan88 said:
ithe old fluid was red, like ATF but very thin...
Sounds like ATF to me.
I wouldn't have even flushed it with gear oil. FLush the old gear oil out with ATF then drain the trans.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Oct 10, 2005
#19
  • Oct 10, 2005
  • #19
does ATF break down when aged or something???
i mean this old fluid that came out was like water pretty much. i was afraid the ATF was too thick, was like syrup.
so just flush it with thick ATF and fill with dexron mercon ATF ( red stuff) when the times comes??
maverick0716
3,924
Oct 11, 2005
#20
  • Oct 11, 2005
  • #20
ATF is way thinner than gear oil
1 of 2 Next Last
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
