T5 issue
  • Thread starter Thread starter redfox91
  • Start date Start date Jan 10, 2007
R
redfox91
94
Northwest Arkansas
Jan 10, 2007
  • Jan 10, 2007
I have 1990 5.0 with a T5. It makes noise in all gears except 4th. It also makes noise in neutral when the clutch pedal is not depressed. It also grinds when going into gears sometimes. I cant downshift from 5th to 4th without putting it in 3rd first.
Can this be the throwout bearing? The bearing retainer? The pressure plate?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 10, 2007
  • Jan 10, 2007
the issue with not being able to down shift from 5th to 4th is a syncro problem. The noise issue you have sounds like the throw out bearing.
5.0 Nostalgia
904
CT
Jan 10, 2007
  • Jan 10, 2007
The noise when the clutch is not depressed is almost definitely your throwout bearing. I would first take a look at the clutch cable and make sure it's properly adjusted. Probably not your problem, but it's a lot easier that pulling the transmission and clutch. Also, try double clutching to see if the grinding goes away. If it does, it's a synchro issue. Then, take it all out and inspect everything.
R
redfox91
94
Northwest Arkansas
Jan 11, 2007
  • Jan 11, 2007
I do have an adjustable quadrant, firewall adjuster, and adjustable cable. I just installed these items thinking it might help in some way, but it didn't.
R
redfox91
94
Northwest Arkansas
Jan 11, 2007
  • Jan 11, 2007
Why does it whine in all gears except 4th? Its not like all the gears are bad but 4th that wouldn't make sense????
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 11, 2007
  • Jan 11, 2007
usally it is a bad idea to use a adjustable clutch cable and a firewall adjuster. It is hard to set up. use one or the other.
Italian-LX
970
Anniston, AL
Jan 11, 2007
  • Jan 11, 2007
You'r cluster gear may be worn at the input shaft -- that would make sense since every gear uses the cluster except for 4th gear.
R
redfox91
94
Northwest Arkansas
Jan 11, 2007
  • Jan 11, 2007
well I only use the firewall adjuster to do the adjusting. It just all came as a package from steeda.
R
redfox91
94
Northwest Arkansas
Jan 11, 2007
  • Jan 11, 2007
IS that a hard fix? Do I need to have the whole thing gone through to fix that?
R
redfox91
94
Northwest Arkansas
Jan 11, 2007
#10
  • Jan 11, 2007
  • #10
What do I need to do to fix this problem???
5.0 Nostalgia
904
CT
Jan 11, 2007
#11
  • Jan 11, 2007
  • #11
If that's the problem you would have to remove the transmission and take it to someone to fix it.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
C
Trans issues.
  • ChrisCruz1972
  • Aug 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
slow84lx
