while your trans is out, inspect the input shaft retainer. If it's grooved AT ALL, do yourself a favor, and borrow the money for a steel unit, it's less than $50, buy from a repitable place only such as hanlon motorsports.
when putting a new bearing retainer gasket on, be sure to not forget to use the old shims, so that you don't have excessive input shaft play. (you can't miss them)
If you have a leak, or slight leak right now, FIX IT. You're gonna mess up your new clutch and soak it with fluid....i've been there too, soaked the damn thing like a sponge. You don't want ANY leaks in the bell area, thats why your trans must have a good seal there, and you must locktite the flywheel bolts and use a good rear main, so oil doesn't leak either.
fixing the leak is easy. My bro had this same problem also. He put a spec clutch in, 600 miles later, the trans developed a SLIGHT front seal leak. We pulled the t5 out and replaced with a tremec 3550, but too late, the clutch already had trans fluid on it and was no good.
A few months later, my father was borrowing my mustang and blew out my fresh t5 because of a REAR trans seal leak he didn't follow up on and add fluid (i've blown a million trannies!) so I was deseperate for a used trans. I re used my bro's old one, just unbolted the bearing retainer, replaced the seal, put the shims back on, and bolted on a steel retainer, and it hasn't leaked a drop since.
just be sure you take care of all your tranny problems, or your clutch job will be for nothing
if memory serves me right, I used silicone too when bolting it up
