there cake to pull off in the car the labor time is .3 of an hour
18 mins to remove the shifter boot and inner shifter trim, remove the shifter, jack up the rear of the car, place on jackstands, remove the 4 DS bolts, remove the driveshaft, remove the h-pipe and crossmember, unbolt 8 bolts holding the tailhousing on, go back into the car, drive the roll pin out of the shifterblock, then go back under and wiggle the tailhousing out while a buddy holes the shifter block and slides it off the rail.....
and then do it all backwards.
I could do that in 18 mins![]()
