So i got this 94-95 5.0 T5 for free but it has a bent mainshaft(unconfirmed). I just broke 3rd gear in my 1986 T5 the other day. I know the 95 has a longer input shaft so i thought i'd just switch em, wrong. The newer T5 has a bigger gear(part of the input shaft) and a bigger tapered bearing...(might be smaller, not sure but they're not the same). So now i'm either looking to buy a 94-95 bellhousing or have the input shaft milled down to the same size as the other. Any suggestions? putting that big gear cluster(the 1 piece shaft at the bottom of the trans) in the newer trans isn't an option because i broke some teeth off that as well. Thanks
