t5 removal
  • Thread starter Thread starter wjhart3
  • Start date Start date Mar 5, 2008
W
wjhart3
18
phila pa
Mar 5, 2008
  • Mar 5, 2008
i dropped a motor and t5 out of a wrecked car only to get it all on road and notice crack in output housing of trans, it leaks bad and onto the exhaust and smokes like its on fire. i got new output housing and seal and am having a heck of a time removing the two top bolts that connect trans to the bellhousing. Any tips or tricks?? can i drop trans down and slide housing off and put new one on? any help greatly appreciated--:
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Mar 5, 2008
  • Mar 5, 2008
Trans..to bell? They shouldn't be any problem. Are yours too tight? Or you can't get a socket/wrench on it?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 5, 2008
  • Mar 5, 2008
If you unbolt the crossmember, you should be able to tilt the engine/trans down some to give you a little clearance to reach between the trans and the trans tunnel. Usually the hard ones to get to are the top two bellhousing to block bolts.
trbkrb
1,976
Houston, TX
Mar 5, 2008
  • Mar 5, 2008
I've always used several extensions to put the rachet back by the tailshaft housing and never had a problem removing the upper bolts.
Good luck on it.
W
wjhart3
18
phila pa
Mar 6, 2008
  • Mar 6, 2008
t5
yes the nuts are too tight and they are hard to get a socket around, i've went thru two u joint sockets- the top two are the ones, they go into bellhousing--the bottom two were also extremely tight but managed to get off with a breaker bar
V
v8only
2,378
22
49
Mar 6, 2008
  • Mar 6, 2008
bigger breaker bar with an extension on the end of it.
1987stangman
684
24
  • Mar 6, 2008
Yea, I remember those bolts... In my case I had just one bad seed that I ended up using a mini air die grinder on the head of the bolt. Be careful not to hit the tranny! Since the tranny side is not threaded, once the head of the bolt is off the tranny will slide back and off. You can then get the rest of the bolt out the bellhousing and go to napa and find a replacement.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Mar 6, 2008
  • Mar 6, 2008
Make sure you are using impact grade extensions and sockets. The regular "chrome" style extensions will actually twist a little bit not allowing you to get all the torque to the bolts. I like to use a impact swivel socket on a long extension and then use a breaker bar to break them lose.
W
wjhart3
18
phila pa
Mar 7, 2008
  • Mar 7, 2008
t5 craziness
thanks for replies, the bolt is gettin rounded after breaking 4 sockets, just got an impact socket to use,may just pull trans off with the bellhousing attached-- this last bolt is making me suicidal--
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Engine 1990 5.0 bogs and pops over half throttle
  • Sander
  • Aug 1, 2025
Fox 5.0 Mustang Tech Aug 2, 2025
AeroCoupe
