T5 shaft question
sweet88gt
334
Venice FL
Recently I had the pleasure of damaging yet another t5 tranny. I have a t5z and on the entrance to the interstate I decided to go for a high speed run. When shifting into 5th I must have chewed up the syncros. Is 1st and 5th on the same shaft? When I ease into 5th no problems, but if I am at any speed above 55mph it will grind. Does anyone know where I can get a exploded diagram of the tranny?? Thanks
The problem wasnt with a powershift as much as these trannys just dont hold up well. I have never powershifted but it does see its abuse 1st thru 4th. This time I shifted into 5th at a excessive speed I figured the syncros just werent up to the task. Another lesson learned.
the fifth gear synchro is made of brass hence it cant handle the high rpm 4-5 shift. The reason it probably grinds every time now is because the raised ridges on the synchro that grabs the gear are probably smashed flat, or worn and it cant grab the gear as well (above 55 in your case) Ive rebuilt my tranny twice this summer, the second time cuz i used a cheap ebay synchro kit and 1-2 and 4-5 wore out just over the summer. I got a ford racing kit and its much better now.
On a side note, How hard is the t56 swap?? Are there are drawbacks to the six speed?? I am done messing around and need to limp this along until funds are ready. I would be using it mainly for the weekend toy, yet easy enough for the wife. Any suggestions welcomed.
just tore apart my t5 second time, first for a complete rebuild, second because the cheap rebuild kit had cheap parts, and one of the 3-4 slider uh... things. they go between slider and the slider splines and rock back and forth on the c-springs, dunno wut to call them, anyway one broke and lodges itself into the synchro... **** happens
