T5 speedo gear
  • Thread starter Thread starter Rapid
  • Start date Start date Feb 21, 2007
R
Rapid
297
Columbia, SC
Feb 21, 2007
  • Feb 21, 2007
I am putiing a T5 in this weekend. Went to the Ford place to pick up the speedo gear. It is much smaller than the hole it gos in. Does the cable have a shroud or casing that holds it or do I need to exchange it?
Thanks!
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Feb 21, 2007
  • Feb 21, 2007
Huh?
The gear should slip onto the end of your speedo cable. It should be roughly the same size as your old one.
R
Rapid
297
Columbia, SC
Feb 21, 2007
  • Feb 21, 2007
jikelly said:
Huh?
I have never looked at one before. I'll pull the C4 gear out and look.
gbarber
158
delaware, ohio
Feb 21, 2007
  • Feb 21, 2007
The gear is supposed to be smaller than the end of the cable that fits in the hole. I just re-used my old C4 gear in my T5. Did you change your rearend gear ratio, or did you just want to use a new gear?
R
Rapid
297
Columbia, SC
Feb 21, 2007
  • Feb 21, 2007
It did not occur to me that I could use the old gear. For 7 bucks I'll go ahead and put in a new one.
Thanks!
gbarber
158
delaware, ohio
Feb 21, 2007
  • Feb 21, 2007
True. Can't hurt to replace the old one. Just be sure the new gear has the right number of teeth.
BornInAFord
199
Bend, OR 97701
Feb 21, 2007
  • Feb 21, 2007
And make sure it's a RH one (teeth angled bottom left to top right as you look at it sideways with the cable end up. The C4, C6 and T5 are RH teeth, the T10, toploader and 3.03 are LH threads.
Daniel
R
Rapid
297
Columbia, SC
Feb 22, 2007
  • Feb 22, 2007
Daniel
Thanks!
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
T5 identification
  • 3054tony
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
AeroCoupe
