edited
I have a few questions, fairly specific (xept the first one), about the swap. Thanks to bottlefed70 for his writeup a few months ago which greatly helped direct the questions (I saw in the FAQs people had mentioned a T5 swap FAQ was going to go up.. is it up yet? Didn't see it in my search)...
1) What is essential in a rebuilt/new T5 that will help it withstand a 400 hp/400 tq 351w in a 3200 lb car with standard tires (it won't be drag raced, but driven in a spirited manner)? I see 'performance' rebuilt T5s on ebay for 900 or so... and I'm going to ask my local transmission shop what he'd charge for something similar. Essentially, what are specific features to any T5 that I should make sure to ask for to make the transmission last? Right now my engine probably wouldn't challenge the T5 too much, but I'm planning on running something roughly akin to the aforementioned ratings in time...
2) What are some flywheel/bellhousing/driveshaft length/spline matches/ etc combos that will work with a 65-66 T5? I see in another thread someone is having some issues with the having the correct flywheel size and tooth # for a given bellhousing... i'd like to avoid that...
3) I had heard that the C4 and T5 have the same length driveshaft. Is this true? Will the u-joint need to be changed (i'm assuming thats a yes)?
4) I see most people buying used clutch pedal assemblies off ebay. Is there much risk to this? Do any of the major companies sell kits with the parts you need to install new ones (the NPD catalog had new clutch pedals and then piles of related parts, but i didn't see anythign like a kit... that might be asking too much, I suppose)?
5) Any opinions on hydraulic vs cable clutch? And any opinions on what clutch i should use?
6) How much fox-body stuff can you use? I noticed bottlefed70 re-used a fox flywheel, and used a fox clutch cable and some other things. With fox performance components as plentiful as they are...
7) How well do shifters like Pro 5.0s (the favorite of late models) work in classics?
8) I have heddman long-tube (well, i think they're considered longtubes, i suppose they're somewhat borderline) swap headers for my 351w.. will they interfere?
Anything you can tell me is greatly appreciate. If there are any other major things I should look for, please let me know.
edit: in case anyone was wondering, the C4 issues were a combination of the carb runnign too rich and a vacuum leak, giving the (false) impression of the transmission slipping. C4 needed some more fluid and is now shifting perfectly, the things a trooper
