Recently did the aod to t5 swap using a new t5, king cobra kit and a cat billet 50 in/oz flywheel. I now have a quite severe vibration at 1000-1400 and again above 4200 rpm (vibes the same either moving or siting still in neutral). I've put about 50 miles on it witout much change. I know the cat-fly could be crap but want to verify it. When I put the pressure plate on the flywheel it was extremely tight lining up the dowel pins but went on and torqued to 24 ft-lbs. I used an alignment tool, torque wrench and did crossing patterns on all torques. Is it possible to drop the T5, remove the pressure plate and clutch then put the bell/starter back on and start the engine (supported under the bell)? I figure if it still vibes then, it has to be the flywheel. The dampner is only a year old and is visually fine.
Please offer any other suggestions. I know the cat flywheel is suspect but thought at the time I bought it that a cat billet would be better than a ford cast iron.
Thanks for all help!
vann
vann
