  • SN95 4.6L Mustang Tech
T5 vs T45....
  • Thread starter Thread starter tjm73
  • Start date Start date Nov 30, 2004
1 of 2 Next Last
T
tjm73
2,418
Rush, NY
Nov 30, 2004
  • Nov 30, 2004
What's the difference between them? Can the FRPP Z spec T5 be put into a 98 GT?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 30, 2004
  • Nov 30, 2004
Nope...different set up all together. Won't mate up to the block.
T
tarch at school
272
  • Nov 30, 2004
you will need a custom bellhousing... and i am pretty sure the t45 is a bit better than the t5... since the t5 is used in the newer V6's
billyfe390
573
  • Nov 30, 2004
If you can get a T-5 with the right bellhousing do it or you can get a TKO. You can beef up the T-5 but with a T-45 you are left in the cold on parts. G-force makes all kinds of stuff for the T-5 but with a T-45 the only thing you can upgrade is the 3-4 shift fork and thats a ford piece.
chevyboy_z28
66
Wixom, MI
Nov 30, 2004
  • Nov 30, 2004
just go with a t-56 and call it a day !
T
tjm73
2,418
Rush, NY
Nov 30, 2004
  • Nov 30, 2004
The T45 is better thanthe stadard T5, but the FRPP Z Spec T5 is better than the T45.
T
tjm73
2,418
Rush, NY
Nov 30, 2004
  • Nov 30, 2004
The tranny has nothing to do with bolting up. The bellhousing determines what bolts to what.
Joes95GT
3,132
Delaware
Nov 30, 2004
  • Nov 30, 2004
The T5Z should will work with a SOHC 4.6 if it works with a DOHC 4.6. I've seen it in a DOHC. The T5Z is perhaps a bit stronger than a regular T5 with it's 330 ft/lb rating. The only real difference is that you have a slower 1st gear (2.95 compared to the WC T5's 3.35).
I would think you mod motor guys would want the 3.35 first gear to make up for some lost torque....
Joe
T
tjm73
2,418
Rush, NY
Nov 30, 2004
  • Nov 30, 2004
Joe
The gear ratio is why I'm interested in it. The 2.95 with 4.10's is a little less then the 3.35 T45 1st gear with 3.73's, but 2-4 are closer ratio and over drive is about the same as the stock T45 with 3.73. First gear is already kinda short with 3.27's so the increase with a 2.95 plus 4.10's would be good and then the 2nd-4th would be basically the same as having 4.10's with a stock T45 and then 5th would still be economical on the highway becasue of the .63 ratio inte Z-Spec box.
Basically get it into the power faster and keep it there with the close ratio's.
6Stang7
1,470
Livermore, CA
Nov 30, 2004
#10
  • Nov 30, 2004
  • #10
Yes but the t-45's bellhousing is part of the tranny itself. You can't remove the bellhousing like you can on a T-5.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 30, 2004
#11
  • Nov 30, 2004
  • #11
T-5 Installation length 23.5 inches (removable bell housing)
T-45 Installation length 31.6 inches (non removable bell housing)
T-5 10-spline input shaft 28-spline output shaft
T-45 has a larger output shaft
Possible, maybe with a fair amount of machining, mix and match parts and work….but not cost effective!
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 30, 2004
#12
  • Nov 30, 2004
  • #12
They are two entirely different transmissions. They have similar names, but are nothing like. The t-5 is a Borg Warner Design while the T-45 is a Tremec design. Tremec later bought BW, but not until after the T-45 was designed. Internally they are similar, but nothing will interchange at all. The t-45 is a tad bit stronger (330 ft-lbs) and offers a synchronized reverse. The bellhousing is integrated into the t-45 design and is machined for a 4.6L block. It will not bolt up to a 5.0 block.
The T-5 has a separate bell, but the bell is machined for a 5.0 block, not 4.6L . Adapter bells can be made perhaps but the lenght of the trans is different as well. Also T-5's are rated in the 275-330 ft-lb range depending on what year and model trans. There is aftermarket support for the t-5. G-force offers kits that will take the T-5 up to the 600HP range. Advantages are that it would be just as strong as a TKO 500 or 600 but be a lot lighter and shift better. The t-5 has an excellent synchro design, but it's weakness is strenght of gears.
The T-3650 trans put in 01+ Mustangs is stronger than then both. It's rated at 360 ft-lbs and is stronger than the original TKO. This trans is tough, but it's weakness is it's synchros. Lots of issues on the 1-2 shift.
If only Tremec could blend the T-3650's strenght with the t-5's shifting ability.
Joes95GT
3,132
Delaware
Nov 30, 2004
#13
  • Nov 30, 2004
  • #13
I agreed up until this point. You haven't seen too many busted T5's have you? They are weak BETWEEN the shafts. What I mean by that is the shafts separate, not allowing the gears to remain "together" anymore.
I've also seen busted input shafts.
I've seen one of these bust into pieces (literally!) launching on slicks. I can say with positivity that I (personally) would take a T5 any day of the week. T5's are time-tested-tough-as-nails tranmissions. Plus, they are a hell of a lot lighter than all other transmissions made by Ford.
If I were limited to using a Ford made transmission (excluding the T-56) I would use the T5 every single time. And, for about 100 bucks, you can rebuild it when you find enough power (or strength) to blow one up.
Joe
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 30, 2004
#14
  • Nov 30, 2004
  • #14
Joes95GT said:
I agreed up until this point. You haven't seen too many busted T5's have you? They are weak BETWEEN the shafts. What I mean by that is the shafts separate, not allowing the gears to remain "together" anymore. I've also seen busted input shafts.
Yes i have. I rebuild T-5's all the time.
3rd and the input shaft break all the time. The teeth shear right off on them.
The reason 3rd blows is due to the mainshaft deflecting. 3rd is located the farthest from any support. It's in the middle of the trans case. Under load, the forces on the gears try to push them apart. The teeth separate to their thinner points and eventually just shear right off.
G-force has an upgraded mainshaft designed to minimize deflection so that 3rd gear won't shear. They also have upgraded gearsets and input shafts.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 30, 2004
#15
  • Nov 30, 2004
  • #15
Joes95GT said:
T5's are time-tested-tough-as-nails tranmission.
I'll have to disagree with that one. Inexpensive to manufacture for a wide variety of vehicles, smooth shifting and mass produced sure, but time tested…. Maybe after about a dozen updates over the years, but tough as nails…not even close.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 30, 2004
#16
  • Nov 30, 2004
  • #16
I love how T-5 parts are just so easy to find.
Hell, i just go around taking junk T-5's nobody wants and slapping them together to make 1 good trans. If you know how to work on them you really have nothing to worry about just as long as you can keep the parts coming in. Easy transmission to work on.
The T-45 and T-3650 are a bit more involved to disassemble/assemble.
Joes95GT
3,132
Delaware
Nov 30, 2004
#17
  • Nov 30, 2004
  • #17
But now you have the issue of all this stuff in the chitty T5 case, which isn't that strong.
I've seen T5's live much further beyond their "peak torque rating" than any other transmission. I've seen T-56's in Cobras (and Camaros, right?) blow to pieces. In one case, there was a cammed LS1 on slicks, he brought the revs up to 6700, side stepped the clutch, and that's all she wrote. I watched a Cobra this past Friday night at the race track pull second gear and the only thing you heard from there was gears rolling around in a case. This was on street tires, too.
I learned to drive a stick shift with my car. I learned to power shift in my car. I couldn't even count how many WOT missed shifts I've had. I'm willing to bet that I've got 250+ WOT, 6000+ RPM powershifts on my stock T5. What does that prove to you? Well....nothing, really. It's my opinion based on my experiences.
Joe
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 30, 2004
#18
  • Nov 30, 2004
  • #18
G-force also has an upgraded T-5 case to take care of that problem as well.
The T-5 aftermarket is starting to come around. It's kinda the reason why i would rather stick T-5 than swap it out for a T45, t3650, tko500 or 600
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 1, 2004
#19
  • Dec 1, 2004
  • #19
Joes95GT said:
But now you have the issue of all this stuff in the chitty T5 case, which isn't that strong.I've seen T5's live much further beyond their "peak torque rating" than any other transmission. I've seen T-56's in Cobras (and Camaros, right?) blow to pieces. In one case, there was a cammed LS1 on slicks, he brought the revs up to 6700, side stepped the clutch, and that's all she wrote. I watched a Cobra this past Friday night at the race track pull second gear and the only thing you heard from there was gears rolling around in a case. This was on street tires, too.
Joe
Yup, I've seen a few T-5's that have a had good luck too. I've also seen plent break including 2 at the track with nothing more than street radials and even one break under nothing more than a hard downshift. My father has been a Transmission Tech for the last 40-years and I've seen more than my fair share of T-5's work their way through his shop. The T-5 is a good tranny, but as a whole, not a tough one.
I
igotyofire
774
Southern California
Dec 2, 2004
#20
  • Dec 2, 2004
  • #20
But when does the case become an issue on a daily driver? ..also isn't their some problems that the g-force trannies have?
1 of 2 Next Last
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T5 identification
  • 3054tony
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
AeroCoupe
