T5-Z doesn't like to shift when hot
  • Thread starter Thread starter i8yoboty
  • Start date Start date Feb 16, 2012
i8yoboty
18
Riverview, FL
Feb 16, 2012
  • Feb 16, 2012
I have a T5-Z in my 90 GT that I bought new. Lately, it has been hard to shift into first gear after it has warmed up. While sitting at a light, I usually pop it into neutral, then when I try to shift it back into first, it feels as if I am hitting a wall. If the car is moving slightly, it will engage however. Any clues?
The_Dude
137
Western Oregon
Feb 16, 2012
  • Feb 16, 2012
First thing I'd do is change the fluid to synthetic.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 16, 2012
  • Feb 16, 2012
Check the clutch adjustment...
Clutch adjustment
Do the clutch adjustment first before considering any other problems. With the stock plastic quadrant and cable, pull up on the clutch pedal until it comes upward toward you. It will make a ratcheting sound as the self adjuster works. To release to tension of the stock quadrant, use a screwdriver to lift the ratchet paw up and out of engagement with the quadrant teeth.
A binding clutch cable will make the clutch very stiff. If the cable is misrouted or has gotten too close to the exhaust, it will definitely bind.
Clutch pedal adjustment with aftermarket quadrant and cable: I like to have the clutch completely disengaged and still have about 1.5” travel left before the pedal hits the floor. This means that I have only about 1” of free play at the top before the pedal starts to disengage the clutch. Keep in mind that these figures are all approximate. When properly adjusted, there will not be any slack in the clutch cable. You will have 4-15 lbs preload on the clutch cable.
The quadrant needs to be replaced if you use any type of aftermarket cable or adjuster. My preference is a Ford Racing quadrant, adjustable cable and Steeda firewall adjuster. The adjustable Ford Racing cable is just as good as the stock OEM cable. It allows a greater range of adjustment than a stock cable with a aftermarket quadrant and firewall adjuster. Combined with the Steeda adjuster, it lets you set the initial cable preload and then fine tune the clutch engagement point to your liking without getting under the car.
Using a stock OEM cable, firewall adjuster and a single hook quadrant may result in not having any free pedal travel before the clutch starts to disengage. I found this out the hard way.
The binding common to adjustable cables is often due to misplacement of the adjusting nuts on the fork end of the cable. This will also cause the cable to wear and fray. Both nuts should be on the back side of the fork so that the domed nut faces the fork and the other nut serves as jam or locknut to the domed nut.
i8yoboty
18
Riverview, FL
Feb 16, 2012
  • Feb 16, 2012
Thank you for your answer.I have a Ford adj. cable with a Steeda quadrant and firewall adjuster.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,118
224
Massachusetts
Feb 17, 2012
  • Feb 17, 2012
What trans fluid are you running?
Also, I'd prob suspect a clutch issue as well...specifiscvly clutch drag.
When the trans gets hard to shift, turn the car off. Does it shift better now?
Now start car, push clutch in and count to 10 and then try to put in gear. If its still hard to get in, I'd suspect clutch drag.
Sent from my iPhone 4S using Tapatalk
i8yoboty
18
Riverview, FL
Feb 17, 2012
  • Feb 17, 2012
I'm using Dexron III. What is clutch drag? I am assuming that means the clutch needs adjustment.
Admin Dude
Jan 4, 1985
43,544
21,712
234
Box behind Walmart
Feb 17, 2012
  • Feb 17, 2012
Clutch adjustment
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
