Tachometer?
  • Thread starter Thread starter cobra2798
  • Start date Start date Sep 27, 2006
cobra2798
303
Clermont, Florida
Sep 27, 2006
  • Sep 27, 2006
Im thinking of buying a autometer tach for my 5.0. I know in my 01 Cobra I needed a tach adapter to use an aftermarket tachometer, do I need a tach adapter to use a tahometer on the fox? Besides a screaming demon coil im running a stock ignition, I dont know if that matter. Again im new to the fox so any help would be great.
1slowfiveoh
47
Bay Area, CA
Sep 27, 2006
  • Sep 27, 2006
No, you will not need a tach adapter in your fox.
Stangdriver627
25
  • Sep 27, 2006
Here's how to wire the tach, or at least what wire connects to what.
• Red = key on power supply
• Black = common chassis ground
• White = dash lighting power
• Green = tachometer signal for standard or electronic ignitions
• Yellow = used only on Internal Coil Magneto tachometers as the signal wire
• Twin Black = (looks like a lamp cord) is used on External Coil Magneto tachometers that use an inductive pick up (#5210)
• Gray = for tachometers that use a Hi/Lo shift light. When grounded, Lo shift light point is active. When ungrounded, Hi shift light point is active.
• Blue = used on Playback tachometers to start recording (see playback tachometer instructions)
Here is the wire you must tap the tachometer into and it's location.
Tachometer Signal Wire Installation
for 5.0 engine(s)
Dark green with yellow stripe wire at ignition coil
Hope this helps.
~Alex
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
65 Mustang: Tried to install a tachometer from Oreilly's with no success.
  • spearce
  • Mar 26, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 19, 2026
spearce
G
Engine PATS off pcm for 1999 Explorer 5.0 swap
  • GOvert
  • Dec 23, 2025
Fox 5.0 Mustang Tech Jun 14, 2026
GOvert
G
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
