thinking about getting an intake soon, just wondering which of the two you guys would go with if pressed between JLT cold air, or the KN FIPK...any thoughts would be appreciated!
Which one do you think looks better?
I was not trying to imply anything with my question. I simply think both products you mention are equally good and that the deciding factor will most likely be looksknew that was coming...i know the gains expected are minimal...but is there really a difference with the "cold air" from inside the fender well?
Also i kind of like the fact that the FIPK is K&N, and for some reason i feel that it is larger...
amongst this, however, im still starting to lean JLT...
So you are saying the gains are minimal and he should instead spend some money on something that also produces minimal gains?Like Dragstr05 said,....the gains are minimal and your better off spending the money on a TB/PL combo..
I had the FIPK in for 3 months and soon the heat shield rubbed a hole in the metal coolant hose for the A/C. I was NOT happy. My fault I guess for not checking for proper clearance, but I saw a lot of satisfied people on here who used it and just expected it to install perfectly.
Good system, but beware and don't be afraid to trim down the shield to make room for essential components. Lesson learned for me.
