OMFG...you guys make me out to be a freaking idiot. I know wtf a unibody car is and how the car is held together by the independent frame rails. I have been doing old Mustangs for 3 years. I was just wondering if any racers out there have any insite on taking off the body. If you do old hodrods and chop and channel them, you ALWAYS brace them side to side on the interior to keep the body in its origional shape. The bracing keeps it from warping. Well to all you smartasses that think Im stupid, will the body be effected at all by not being held together by the front and rear frame rails? The front and rear rails are sorta lengthy (mainly the front) and there is a lot of leverage put on the body of teh car to hold it up. Will taking off hte rails effect this??
My plan no thanks to anyone here is the following:
Mount on quick home built subframes (or lack there of) and take the body off. This will keep the frame rails in the spot where they were origionally mounted. The theory is to have a complete frame of a car to copy the new frame off of.
Cut the frame rails out and I should have a stripped body of a car to remove.
Build the new frame out of 2x3 box tubing mimicing the old frame. Only difference will be the rear will be about 6" narrower with a ladderbar or 3 link setup.
The front will be a little different with a boxed in front end and all square tubing for a radiator support etc... The car will also be getting a MustangII front end with full tubular upper and lower control arms, dropped spindles and coilovers.
The motor will be a home built twin turbo 5.4L DOHC Navi motor. This idiot just happens to have Modular Performance backing me up as a sponsor for the motor, they know how dumb I really am.
Trans will be an X2C Motorsports TKO, custom made driveshaft and a Fab9 rear end housing. 4.11 gears, strange axles and 18" wheels.
Rear tires will be 335's or 13" slicks..
I promis there has been a lot of planning, and thought into this. I was just looking for some help on taking the body off without warping anything or letting the body get messed up. Thanks for nothing
Tim
