Taking the leap.
DRock9
359
Well...i pulled into my GF's house the other day and to my surprise I look over and see anti-freeze sprayed all over the passenger floor. Heater core is gone!I checked my coolant and it was low but the temps were normal. So i filled it with water and got a quote from my mechanic...$600 including parts. No thanks! It's been off the road for 3 days and I wanna get it back on soon so I am choosing to do the work myself.
I had the option to have my dad pay for it all but i figured what will i ever learn by having someone else do the work. So I am choosing to do it myself...Now here is my question(s).
I have never worked on a car in my life, I am 17 and this is my first. I do have a go-kart, many R/C Cars which run on gas, and i used to build Battlebots. So id like to think i am mechanically inclined.
How hard will this be for me to do? I have the dairections thanks to :SNSign: and ive gone over them.
What is the potential for error and how bad can it go?
Any tips before i start? I know its probably not reccomended to replace a heater core as your first thing ever but i figure if i do the hardest it can only get easier. I dont want to pay $30 for a part and $570 for labor.
Thanks!
I sold a 1987 GT because it had a bad heater core a few years back --- it is a pretty bad job and I work on all kinds of things all the time and do it in my spare time as my Mustangs are just toys I drive when I want and leave them in pieces for days if I have to. However before I sold that 87 GT I put "BARSEAL" in the radiator to stop the leak - IT WORKS GREAT!!! but it is bad for your whole cooling system and do not consider it a permanant fix. It is made with crushed walnut shells believe it or not - under heat and pressure it finds the leak and expands to stop it up. You can get it from any automotive parts store for less than $5. You can also bypass the heater core by removing the hoses from the firewall area and clamping them together on a tube so the water just circulates back to the engine if you need to buy some time in order to do the job at a better time. It is not that I have not personally replaced several heater cores in the past but they have all been in 1970 mustangs -- I can now do a non-a/c 1970 heater core in about an hour and an a/c 1970 Mustange core in 2 hours. The fox body mustangs are a bear to get to the heater core. Mustang Monthly magazine had a detailed article a few months ago on just this thing. It can be done with lots of patience. Be careful to remove all screws, bolts, nuts, etc.. that hold the dash in the car and do not force anything - if it does not move in a particular area then it has a bolt or something holding it in - FIND IT and remove it!!! I would remove the front seats and console first in order to get as much wiggle room inside the car - you are going to need it. Expect the job to take all weekend and do it inside or under a carport if at all possible. Buy new heater hoses while you are at it and make sure you get FORD for the supply side as it has a built in restrictor to stop the core from blowing up in a month or so -- I have done that before - no restrictor = blown heater core in very short order. All I can say is GOOD LUCK!!!!
If your car doesn't have A/C it is really easy. If it does it means tearing apart your dash which can be done its just a little harder. First thing you should do is go buy a manual for your car so you can do the repair step by step.
Mine blew last week and Ive gotta get it fixed. I helped my cousin with his several years ago on an '89 GT and wont do it again. The whole dash needs to come apart.
The cheapest quote I got was $462+ tax.
A guy I know thats doing my gears said he'll be able to do it next week. Since the Mustang isnt my daily driver its not really a problem.
Id rather spend the money to make the car faster though.
You better have someone with you who has worked on a car before if your gonna do it, imo. It's a 10 hour job for someone who hasn't done it before and requires disassembling the dash if you have a/c which is gonna be real fun. And I think the heater cores are sort of sensitive so it won't take much to damage one. You can do it yourself, but plan for several hours of work, and take your time. Do it right or do it twice, and you definetly don't want to do a heater core twice.
I have done my 79 three times and my 89 Lx once. The first time I did the 79 it took me 18 hours. Last spring I did the 89 in 5 hrs and 33 minutes.
Plan on doing it on say, a Sat, so you have Sunday if it does not go as planned.
Search here and elsewhere, as either here or on another site, I found a complete article, with good photos on how to do it, and it really helped. The 89 was easier than the 79, as only the speedometer cable had to be unhooked, and the gage cluster stayed in.
You need either a Chiltons, one of the articles mentioned, or the Ford shop manual, since the location of all of the bolts is not at all obvious. Once you know where the bolts are, just proceed carefully. I got the last core out by carefully bending the heater box cover up, therefore not having to remove the screws next to the firewall. Somewhat hairy, but it worked.
Or you can just bypass it for the time being. Not sure where you live or how often you use your heater/defrost...if it isn't that often, or you just need to buy time until you can replace the core...just use a coupler and connect the two hoses going into the heater core together. In Florida it is common to see those two hoses connected together, as we really don't need the heater all that much.
I actually replaced mine last year, and have yet to actually use my heater. If I had to do it again...I wouldn't have done it. I would have bypassed it and forgotten all about it.
