  • SN95 4.6L Mustang Tech
Tapping the sensor for PI swap
  • Thread starter Thread starter RysRed96GT
  • Start date Start date Mar 23, 2004
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Mar 23, 2004
  • Mar 23, 2004
alright, im still confused. i realize there are now two different sensos for the 96-98 GT's. im assuming they're still going to be in the same positions on the new intake. but my question is tapping. for the 2000 intake manifolds, i understand we are supposed to tap the T-stat housing, correct? my confusion is, wouldnt this cause different temp readings since it's above where the tstat opens and closes? or would it not matter? im asking because on the 98 intake, it's on the cross-runner, but it probably wont have the same effect if tapped into the top of the tstat housing. but could this still work? is this how everyone else is doing it?
also, which sensor controls what? one senses for the computer, the other senses for the gauges.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 23, 2004
  • Mar 23, 2004
its not going to matter
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Mar 23, 2004
  • Mar 23, 2004
so tapping into the tstat housing, even though coolant isnt flowing through it the same way as it would on the intake runner, would still work? do u know what that sensor would control, the gauges or comp?
athensoutkast
33
Ga
Mar 24, 2004
  • Mar 24, 2004
standing in front of the car, the one on the left goes to the guage. the one on the right that you have to tap is for the pcm. should be a flat spot next to the thermostat housing. that is where I put mine.
Xanax
103
  • Mar 24, 2004
Ry I heard people actualy doing the swap would weld
a post on the thermostat housing and attach the second sensor to the
new post.I think the swap is an aborting to get everything too work out
right!
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Mar 24, 2004
  • Mar 24, 2004
athensoutkast - there is no flat spot on mine, the 99 and 00 ones do not have the bare aluminum crossover piece wth the area next to the housing to tap. mine is the 00 manifold and doesnt have this section, so my guess is to tap the metal housing over the tstat, but i wanted to make sure this method was used before and is sucessful.
athensoutkast
33
Ga
Mar 24, 2004
  • Mar 24, 2004
My bad! I guessed all the PI intakes had the Al crossover. mine is from an '02. great job on the pics. I would like to see it after you are finished.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 24, 2004
  • Mar 24, 2004
My thermostat housing itself is tapped and I have no trouble at all.
ChadS98GT
1,924
Parker, CO
Apr 1, 2004
  • Apr 1, 2004
Does anyone have any pics of this stuff?? I am going to be doing this soon and need advice/help
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Apr 1, 2004
#10
  • Apr 1, 2004
  • #10
pics will come tommorrow. it looks like it seems, it's a gray sensor sticking out of the top of the metal housing
billyfe390
573
#11
  • Apr 2, 2004
  • #11
If you have the newer block there is a plug in the water jacket on the drivers side near the back of the block put it there. If you are like me and the plug is behind the motor mount you will need the following.
1. 3/8 NPT tap
2. 9/16 drill bit. On the tap it says to use a 39/64 bit which is impossible to find use the 9/16 because it is .002 smaller and you will need it a little tight.
On the top of your t stat housing there is a kinda small flat spot locate the center of that. Drill the 9/16 hole then tap it with the 3/8 NPT tap. Be careful and get this as straight as possible and run the tap down until it gets fairly tight and use some kind of lubricant whil you do it. The reason I say take your time is you will only get 1 or 2 threads in the thin aluminum. When you get the hole threaded use some pipe sealer (not silicone) on the sensor and screw it in.
You will notice a small variation in the readings when it is cold and warming up but at operating temperature everything is normal.
Super dave
18
Memphis, TN
Apr 2, 2004
#12
  • Apr 2, 2004
  • #12
If you want one of the updated intakes with aluminum crossover, there is a guy who is selling them for $140 shipped. PM me for his info.
Dave
Madi98GT
293
Naperville, IL
Apr 2, 2004
#13
  • Apr 2, 2004
  • #13
That's where I put the second temp sensor (the one for the gauge) on my PI swap. It works perfect, all you have to to is extend the wires and it threads right in.
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
T
Newbie here with an odd story
  • thequadfather
  • Jul 20, 2024
  • The Welcome Wagon
The Welcome Wagon Jul 22, 2024
thequadfather
T
