Taurus fan and windstar fan
lincoln+ford
195
I got a windstar fan out of a junkyard looks like the taurus fan.I have it mounted already was pretty easy.When i was taking the fan off the van i noticed there were 3 relays for the fan.And the plug has the ground wire in a seperate connector then 2 power wires and off one of the 2 power wires another wire branches off of it(so theres blue /white stripe wire and 1 blue /red stripe wire which is the one that branches of).I grounded the fan to the battery then hooked the fan right up to the battery.
Basicly on low speed the wires dont get warm but on high the wires get kind of warm hotish.And i wanna be able to use the high speed.Is this normal?
This is on my lincoln.
It may be possible that simply your battery is pushing more amperage than the battery in the windstar, you can try a bigger gauge wire to prevent it from getting hot. Or put an inline fuse in the wiring so just in case something goes wrong the fuse will just blow.
Do relays control the amount of amperage thats allowed to go threw?Or do they simply just act as a high current switch?Idk i like to use the low speed as a daily cool off and when its gets in those hot days or when i get my 408w in use high speed when needed.
relays are just a switch they do not control the amount of current. Current draw is determined by the motor and the voltage applied to it. If you hooked the fan up to several different batteries, as long as the are 12v, the fan motor will draw the same amount of current, provided they are charged. A stronger battery will not "push" more current through the fan motor, the fan will just run for a longer period of time.
If it is getting really hot it could be that the insulation on the high speed windings of the motor is starting to break down, this results in a drop in resistance which will increase the current draw of the fan. If I were to run it I would put a fuse on it. Find out what the amperage of the fan at high speed is and then get a fuse that is larger than that. I.E. if the fan amperage was 20 amps I would get a 30 amp fuse and the appropriate size wire. If you go too large the fuse will not do its job if you go too small you can have nuisance problems with burning up fuses.
