The tax return worked out very well this year so I have a little money to spend on the hot rod (finally!!!) I have 2400$ to spend and want to get the most out of it. The car is a 2002 GT and has 125,000 miles on it. She runs strong and has never had any problems internally. The mods to the car are:
C.A.M. Longtubes (bobo MAC's from what I understand)
Stainless X-Pipe with Cats
Pypes Violator catback
3.73 Gears
Steeda Tri-Ax
Terminator Clutch
Tokiko HP Shocks/Struts
Steeda Heavy Duty Rear Upper Control Arms
Steeda Adjustable Rear Sway bar
Ford C-Springs
Mach 1 CHin Spoiler and grill delete
I put in new motor mounts last year and am going to do the transmission mount, steering bushings, and swap in a cobra steering shaft as the steering has gotten a little loose. I think the longtubes cooked the rag joint.
My long term goal is to eventually have the car supercharged, wheels/tires/cams and get to about 400-420 rwhp on the stock bottom end. When it lets go one day, go to a built engine. My questions are:
1) Is it a good idea to add a supercharger to an engine with this many miles?
2) Since it is a street car, would a roots or centrifugal be better for the longevity of the engine -peak power vs. wider power band?
3) The older Saleen kits use an M90, could the M112 be swapped on later?
4) Is the non intercooled Tork Tech Cobra kit a good option?
5) Would I be better to do the cams/wheels, and lower the car more this year - then do a forged shortblock - then blower? Or get blown and add on?
6) And for opinion and input - Should I go 17 or 18 on the wheels and what are your thoughts on deep dish Bullits vs. FR500's (anthracite as the car is mineral grey)
Any input is appreciated. The money's burning a hole in my pocket as I've been waiting since 2002 to do this type of work so I just want to make sure I don't do something foolish. Thanks.
3.73 Gears
Steeda Tri-Ax
Terminator Clutch
Ford C-Springs
