i was wondering what if anything would i need to change / modify to run a throttle body and mass air off of a 3.8 thunderbird or something. do i need to put bigger injectors in too or will i be ok, any modifications to the intake? and would i gain anything if i just put on a 3.8 mass air for the time being or will it make tha car run like ****? ohh by the way its a 93 2.3l 5 speed with a cold air intake, flowmaster, and one cat removed if that will help in anyway
i stand corrected.... save your cash... i wasn't sure if he did or not... ok so the question is what head to replace it with??? i know that the twin plug heads flow worse than the single plug head, so would you swap in that head??? and if so what to do about the 2nd coil pack??
Good to see some actual numbers, though.
