TB coolant bypass, does it work??
  • Thread starter Thread starter Foxfan88
  • Start date Start date Jul 22, 2006
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 22, 2006
  • Jul 22, 2006
everyone i know seems to do this. I havent yet, i have heard and figure the coolant, while hot, is cooler than the recirculated exhaust.... from the EGR
so does the bypass work??
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 22, 2006
  • Jul 22, 2006
yes it cools the TB not heat it up. leave it the way it is
Mustang5L5
Mod Dude
Feb 18, 2001
43,342
18,071
224
Massachusetts
Jul 22, 2006
  • Jul 22, 2006
Leave it alone
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jul 22, 2006
  • Jul 22, 2006
i was going to. if i try and tell them that they are hurting themselves, they wont believe me.. sucks to be them haha
8950HO
658
  • Jul 22, 2006
The only time to bypass is if your EGR ports on the head are blocked off.
1987stangman
684
24
  • Jul 22, 2006
Whats the point, Ford did not use the TB spacer on the Cobra intake and bypased it. Although I removed and pluged the EGR Thermactor tubes from the heads I still used the TB coolant lines untill I installed a Cobra intake.
Mustang5L5
Mod Dude
Feb 18, 2001
43,342
18,071
224
Massachusetts
Jul 22, 2006
  • Jul 22, 2006
This has been argued over countless times.
Either way, the lines make no difference if you remove them or not. I doublt you'll see any HP change.
SO the effort of bypassing the lines is simply a waste of time on a stock Mustang
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 22, 2006
  • Jul 22, 2006
they are cooling lines not heating lines
fidstang
307
South Lansing
Jul 24, 2006
  • Jul 24, 2006
Ford SVT told me they are there to warm up the air coming into the cold engine upon start up on cold days or mornings!
Mustang5L5
Mod Dude
Feb 18, 2001
43,342
18,071
224
Massachusetts
Jul 24, 2006
#10
  • Jul 24, 2006
  • #10
How would that work? The coolant is cold at start-up?
There have been a few reasons tossed around. Heat to the TB to prevent icing and cooling off the EGR spacer.
Either way, just leave the hoses alone. It's not worth the effort. When you install a CObra intake, then delete them
fidstang
307
South Lansing
Jul 24, 2006
#11
  • Jul 24, 2006
  • #11
Should only take the coolant 5 min. to heat up to 130* and fully warmed up by 15min.
If the air outside is 50-60* it will help warm the air quickly.
You asked the same question I did and that is the respones they gave me.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jul 24, 2006
#12
  • Jul 24, 2006
  • #12
I have read this and heard this from many Mustang and Corvette owners. They said the same thing it warms the t-body on cold days. I have heard that bypassing it adds HP,...but I have a hard time believing that. I know two 85 Corvette owners that have done that, and they have poor idle on start up.
My notch has that thing bypassed, but I got it like that, I am gonna hook it back up soon.
J
Justin_Bradley
26
Richmond, VA 23231
Jul 24, 2006
#13
  • Jul 24, 2006
  • #13
All of this, coolant in throttle body that is, is new to me. Can someone explain it to me, as well as how it comes into play with the EGR valve.
Mustang5L5
Mod Dude
Feb 18, 2001
43,342
18,071
224
Massachusetts
Jul 24, 2006
#14
  • Jul 24, 2006
  • #14
Well, the coolant passage is in the EGR spacer, but it's in the part that is butted up against the throttle body. It surrounds the EGR port and also warms the TB.
I guess it has dual purpose as it keeps the neck around 130-180 degrees. The EGR gases are hotter, so the coolant takes the excess heat away, but at times when the EGR is not active, it is heating the TB up perhaps to prevent icing (which will occur at 40-50 degrees under proper humidity and conditions)
HISSIN50
34
129
Jul 24, 2006
#15
  • Jul 24, 2006
  • #15
I wonder why a heat riser off the header wasnt used instead. That would have allowed one to get hot air almost instantly to the TB.
And on my '94, I guess there apparently was no worry of icing since I dont have the lines. The difference between the two (fox III and IV) is the EGR plumbing. Does anyone else see this correlation (which isnt necessarily causation)?
That supports the heat removal stance, I think. And that has been my postulation for some time. I'm not debating since I don't think we will ever get a definitive answer.
As Mike wisely said, who gives a poop.
Mustang5L5
Mod Dude
Feb 18, 2001
43,342
18,071
224
Massachusetts
Jul 24, 2006
#16
  • Jul 24, 2006
  • #16
Well, the 5.0 isn't some exotic low-production engine. Ford stuffed virtually the same engine in everything else in the 80's and 90's, so some of it's engineering isn't exactly the best for performance.
MeanMussy
581
Louisville, KY
Jul 24, 2006
#17
  • Jul 24, 2006
  • #17
Exhaust gas comes out ~1400*F. Your coolant is kept around 190*F. This isn't an engineering question, it's common sense..
Mustang5L5
Mod Dude
Feb 18, 2001
43,342
18,071
224
Massachusetts
Jul 24, 2006
#18
  • Jul 24, 2006
  • #18
Case closed....
...except the '93 Cobra had the cooling hoses deleted while the '93 Lightning retained the lines on it's GT-40 intake manifold. .
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
