TB overbore
  • Thread starter Thread starter keepinitril
  • Start date Start date Jan 16, 2010
keepinitril
102
Anaheim Hills
Jan 16, 2010
  • Jan 16, 2010
what is the largest anyone has taken the stock 60mm throttlebody to?
PS: what about the EGR spacer?
stykthyn
5,232
2,652
223
gainesville
Jan 17, 2010
  • Jan 17, 2010
usually the inlet for the intake is ported to match the tb. get an exploder tb, with a little modding its a cheap 65mm tb.
keepinitril
102
Anaheim Hills
Jan 17, 2010
  • Jan 17, 2010
i believe I have the one from the explorer now,
so Im left with this stock one to experiment with
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jan 18, 2010
  • Jan 18, 2010
Are you replacing the throttle plate to go with a bigger bore? From what I remember, the location of the shaft bearings for the throttle plate make it pretty much impossible to enlarge the bore without a lot of work, even with a bigger throttle plate to match.
I know from experience the EGR spacer can't be bored much past 65-67mm, you'll break through the wall.
keepinitril
102
Anaheim Hills
Jan 20, 2010
  • Jan 20, 2010
im lookin at the EGR plate right now, and the OD is 75, so youre probably right, now the egr plate the I installed had a bigger OD, I dont quite know what it came from, ill bet its from an explorer, but I just installed a 65 tb and plate that I bought together
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,116
224
Massachusetts
Jan 20, 2010
  • Jan 20, 2010
Unless you are running heads that flow great or a supercharger, no need to go over 65mm.
Just make sure you are running at least a 70mm MAF if Mass Air
keepinitril
102
Anaheim Hills
Jan 22, 2010
  • Jan 22, 2010
i have a nicely done pair of gt40p heads with 1.94 intakes
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,116
224
Massachusetts
Jan 22, 2010
  • Jan 22, 2010
In that case, i might go with a 70mm and port match the intake to it.
You running an explorer intake?
Reason there is no point to porting a stock throttle body larger is because you are still left with a 60mm or 65mm blade.
70mm TB, and perhaps 75mm or larger MAF
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jan 22, 2010
  • Jan 22, 2010
just buy a 70mm and be done with it......
keepinitril
102
Anaheim Hills
Jan 25, 2010
#10
  • Jan 25, 2010
  • #10
Im planning on buying a custom blade from kinsler
giddyup306
3,041
Jan 25, 2010
#11
  • Jan 25, 2010
  • #11
Modifying throttle bodies is much more trouble than it's worth.
keepinitril
102
Anaheim Hills
Jan 26, 2010
#12
  • Jan 26, 2010
  • #12
i guess youre right
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 26, 2010
#13
  • Jan 26, 2010
  • #13
QFT!!!
Speaking from experience. I ruined a couple of perfectly good stock throttle bodies trying to machine them out to 65mm. There just isn't enough wall thickness to work with. By 63mm you've compromised its structural integrity. Meaning a hard bump with the inlet hose installed and you'll snap the neck right off of it.
At 64mm, you can start to actually see the inner wall starting to discolour because you're getting paper thin in spots that you could essentially push through with the tip of a screw driver.
...and by 64 1/2mm, you've broken through and made yourself an expensive paper weight.
The spacer on the other hand will bore out to 65-67mm as stated...but again that's of little use unless you've got a matching throttle body to couple with it.
keepinitril
102
Anaheim Hills
Jan 27, 2010
#14
  • Jan 27, 2010
  • #14
Thanks for the experience lesson
giddyup306
3,041
Jan 27, 2010
#15
  • Jan 27, 2010
  • #15
QFT!!!
Mine was a SVT throttle body. I also modified two Mustang throttle bodies to fit on Contour SVTs (there are no aftermarket TBs available). With that being said it is extremely tedious and you have to be uber careful.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Idle issues….again.
  • Nostang25
  • Sep 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2025
AeroCoupe
P
Engine Help 331 stroker
  • pdmount
  • Feb 19, 2026
Fox 5.0 Mustang Tech Feb 21, 2026
pdmount
P
