TB question
  • Thread starter Thread starter bobbyd
  • Start date Start date Apr 30, 2005
bobbyd
312
San Antonio/Los Angeles
Apr 30, 2005
  • Apr 30, 2005
will it be safe to put a after market TB on my stock intake? will i see a difference? or will doing that f up my car? thankx
bobbyd
312
Apr 30, 2005
  • Apr 30, 2005
btw the TB is a 70mm
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 30, 2005
  • Apr 30, 2005
Its only somewhat worth it IF you pull the upper manifold and take a dremel so the opening of the manifold is 70mm. Might wanna wait until you get an aftermarket manifold.
No, it won't fu ck your car up.
bobbyd
312
Apr 30, 2005
  • Apr 30, 2005
yea i think i might just wait till i get a intake since i will also need a spacer.
what about getting a e-cam and putting it on a stock car (not for long)
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 30, 2005
  • Apr 30, 2005
Forget the E cam idea
squeeeg
1,905
Michigan
Apr 30, 2005
  • Apr 30, 2005
You will not see much from the TB so I would wait for a new intake. Cams don't do much if anything on a stock engine. You also can get a better cam then the e-cam. They are a bit dated and there are much better ones out now.
Curse
791
El Paso, TX
Apr 30, 2005
  • Apr 30, 2005
You don't have to pull the upper manifold to open-up the intake. Just stuff some rags in the opening and grind away, if everything else is stock on your car, I wouldn't waste the time doing it though.
bobbyd
312
Apr 30, 2005
  • Apr 30, 2005
well i just have some bolt ons engine is all stock.
bolt ons include CAI, pulleys, exhaust and shifter. thankx guy so intake it is might get a Typhoon intake and also am looking at getting some headers
Curse
791
El Paso, TX
Apr 30, 2005
  • Apr 30, 2005
The typhoon is a good intake, it is what I am running right now. I would wait on the TB since the typhoon has a 70mm opening as is. Good Luck
bobbyd
312
Apr 30, 2005
#10
  • Apr 30, 2005
  • #10
coo thankx for the info. will i need a spacer or will just getting the intake do?
Funhog
219
Alabama
Apr 30, 2005
#11
  • Apr 30, 2005
  • #11
Is it better than the GT40 intake?
bobbyd
312
Apr 30, 2005
#12
  • Apr 30, 2005
  • #12
nah I think the gt40 is better but the typhoon is like the Eldebrock ones
Funhog
219
Alabama
Apr 30, 2005
#13
  • Apr 30, 2005
  • #13
Thanks
bobbyd
312
Apr 30, 2005
#14
  • Apr 30, 2005
  • #14
Funhog said:
Thanks
no problem but just make sure check and see what other people say/know
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
