I bought an '88 TC for the 2.3T swap into my '92 Notch. I know that the TC's rear is an 8.8" rear with discs and 3.73:1 gears (since it was from an automatic car), but is this a simple bolt on? I think I read that the quad shocks won't bolt up and that the TC rear is about 1.5" wider so it sticks out 3/4" wider on each side. Is that a problem with rubbing in the fenderwells? I was thinking of going with the 16" x 7" Pony wheels or even the 17" x 8" PonyR wheels by MavroMont.com (reproduction pony wheels). Would there be any issues with the wider rear axle? I think the 93 Cobra used the same axles. What size wheels were on the 93 Cobra? Also, would the wider TC axle make it difficult to do a 5 lug conversion; I may want to use the 17x8 OEM 5 lug wheels from my 2001 GT.
Looking forward to starting my swap when I get the time.
Thanks,
WES
Thanks,
WES
Its under something called handling package and was in very small print on there print out of the rack and pinion also located at the very bottom of it.
