  • 1994 - 1995 Specific Tech
TDC Timing Questions/Problems
  • Thread starter Thread starter 94pony
  • Start date Start date May 5, 2009
94pony
151
Arlington, Tx
May 5, 2009
  • May 5, 2009
94 Gt 5.0
Let just start here, I have my motor with no distributor and the motor is not at Top Dead Center (TDC).
-What I have done:
-Pulled the spark plugs
-From the harmonic balancer rotated the motor clockwise
-Put my finger over the spark plug hole, and waited to fell pressure (telling me it is in the compression stoke).
-Put the tip of a screwdriver through the hole and rested it on the top of the piston. Waited for it to come as high as possible before stopping.
Now heres my problem:::
The 0 degrees mark on the harmonic balancer is about a 1" to a 1-1/2" clockwise of the timing mark that has time punched in the metal????????????
What do I do?
Align the balancer and timing mark at 0 degrees?
Thanks for any help..
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 5, 2009
  • May 5, 2009
Lets keep this real simple and explain a thing or two as we go
Assuming your hb has not spun the outer ring with the t marks on it
When you line up the hb 0 mark and the straight edge of the pointer
You will be at either tdc of power or tdc of exhaust stoke
That is a given or known fact and has nothing to do with the dizzy
If you drop in your dizzy and line up the rotor with #1 cap post
You're right on the money or 180 degrees out
Again ... this is a known
See if it will fire up and rev up smoothly
If if dont
All you gotta do is
Lift up the dizzy enough to flip the rotor around 180 degrees
Make sense my friend
Grady
94pony
151
Arlington, Tx
May 5, 2009
  • May 5, 2009
With the spout connector out, she started great.
The timing was at 10btc so I left it.
Plugged in the spout connector and it died.
I adjusted the distributor enough to keep the motor running smooth
and it was off the charts, like a inch counter clockwise of atc...
Im clueless.....????
HISSIN50
34
129
May 5, 2009
  • May 5, 2009
The mark I use is the right-knife-edge of the timing pointer. Not the circle.
If you're still off, you might be in no man's land at the top of the piston's movement. Be sure you are at the true peak and not on a slight ascent or descent.
94pony
151
Arlington, Tx
May 6, 2009
  • May 6, 2009
I have the choice of either lining the timing marks(which i know number one is not at the top), or i can make sure the number one is at the top of its rotation but the timing marks wont line up?
BaBysARM
161
Hickory, NC
May 9, 2009
  • May 9, 2009
i would say that your balancer has spun...is it the stock unit?
94pony
151
Arlington, Tx
May 10, 2009
  • May 10, 2009
I have replaced it before but only to factory specs. Your probably right...
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
G
Help with initial Microsquirt ignition setting
  • germain101
  • Nov 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Nov 15, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
