Context:
• New engine build, 9:1 compression stock bore, stroke
• Stock heads remanufactured and ported by a local machine shop subcontracted by the dyno shop assembling the car
• Stock cams, springs
• New Kenne Bell 2.1L blower, pulleyed for 15-16 psi (Innovators West 10% overdrive/7.5” crank damper, 3.25”upper)
• Robust dual feed fuel system, 60lb injectors, SCT BA3000 MAF
• 500 gentle break in miles of less than 3k rpm, according to Mcleod’s directions (twin disk clutch)
Results:
• Idles smooth, smells like its running rich. No surging, no smoking, no boost spikes. Doesn’t register any OBD2 codes. Exhibits no signs of major failure other than an extremely low dyno graph
• Dyno of 310hp, 380 torque, overboosting to 19psi of boost. 18 degrees of timing, 11.5:1 flat A/F
• Dyno operator says according to Livelink that no timing was being pulled by the knock sensors/ECU. He bumped it up to 23 degrees of timing and got saw hp or torque improvement, and observed no audible detonation
• Shop took the front cover off and re-checked cam timing and it is supposedly right on
• Compression test came out at 120psi for ALL cylinders, with leak down tests ranging from 12% to 32% on cylinder 8
Shops conclusions:
• They can’t explain it and want to send me home with the car as it is. I have already paid over 11 grand in labor for the engine/trans installation.
• The shop thinks that the new bottom end I supplied has bad rings on all cylinders
My conclusions:
• I think that the valves were replaced wrong or the headwork is jacked, as I don’t understand how the compression test could come out all the same but the leak down is so much different
• I believe that if the bottom end, if it were bad, would be smoking badly. The car when I brought it in to them had fragged a cylinder and had 50 psi in one cylinder and 60 psi in another. They called it the Valdez because it blew oil plumes everywhere, and yet still threw down 400lbs of torque at 12 psi of boost—significantly more power at significantly less boost than a completely new motor
• Based upon a conversation with the supplier of the new short block, I believe that the valves are either not fully closing because the stems are too long, or are too short and not fully opening
• It is also possible that the stock valve springs can’t handle the boost and are floating, but that wouldn’t be evidenced in the static compression/leak down tests
I was going to bet the shop that if we re-ringed it and they reassembled it, that we would get the same hp results, and if so they owe me for the labor to have someone else repair/replace the heads. Then it was suggested that we take the motor to a machine shop and disassemble it together with myself, the best Mustang mechanic in Seattle (who should have done the work from the start) and the owner of the shop that did perform the work all present for the tear down and inspection. Unfortunately, it doesn’t seem that there is a local machine shop that knows modular motors well enough to do it.
Anybody have any ideas? Below is the mod list (all parts were NEW when installed unless otherwise noted):
03 Mach 1 aluminum block w/ cobra crank,
ARP rod bolts
ARP head studs
Eagle Rods
Diamond 11cc dished pistons
Original ported B heads from my car, (66k miles) with $2k in machine work to remanufacture them
Original cams, cam springs
New cam gears and cam chains
Milling high volume oil pump
Innovators West 10% overdrive dampener
Thump RRR Racing billet tensioner
Reichart Racing billet idler pulleys
Gates green stripe serpentine belt
Kenne Bell 2.1L chrome supercharger with a factory mounted 3.25 inch pulley
SCT BA3000 MAF
BBK aluminum cold air intake
Accufab SCTB 1694 CFM throttle body
Siemens 60lb injectors (barely used)
Glennsperformance sumped fuel tank
Dual Walbro 255 pumps
Aeromotive billet fuel filter, regulator
Sullivan fuel rails (used)
Even Flow Cooling mod
Stock water pump (that was on my car before the build)
Moroso PCV oil vent/catch can
AC power disconnected
BBK long tube headers and mid pipe (no cats)
Flowmaster cat-back (that was on my car before the build)
Energy suspension poly engine mounts
T-56 transmission with 26 spline input shaft
Mcleod street twin disk
Pro5.0 short shifter
DM Extended Range SpeedCal
UPR billet firewall adjuster and quadrant adjuster
Dynotech aluminum driveline
Innovate wideband
SCT X3 & Pro Racer Package software
Stock rear end gears, axles
New Nitto NT05 315/35/17 tires, with motor break in miles only
Results:
Shops conclusions:
My conclusions:
ARP rod bolts
ARP head studs
Eagle Rods
SCT BA3000 MAF
Innovate wideband
