My car is a prime example of what happens when a previous owner doesn't maintain a vehicle and it gets some miles on it. I think that either my coolant temperature sensor has gone wack or my thermostat is open or something. I'm to go to NAPA to pick up some antifreeze and a thermostat and see what happens. But what happened is, is my temperature gauge sky rocketed up wards (thank god I was only a 1/4 mile away from the house). So I drive it back and park it and there it sits. What's going on is when I'm idling in park it is fine but when I put it in drive or reverse and give it the slightest amount of throttle the temp. gauge skyrockets past the red. I think the thermostat is stuck, coolant temperature sensor went bad or my water pump went bad (even though it's not spraying coolant or making noise). Someone help me out here, thanks.
Something else I just noticed...
I just pulled the stang into the garage and shut it off, well I put the key on ACC (turned all the way back in the ignition) rolled up my windows and the needle moved up and up and up as I held the buttons down, If I let go of both of the buttons the needle stopped moving up, wtf is goin on here. BTW another thing, I just regrouned my battery to one of the AC bolts (one that mounts the AC bracket to the block), think that could be the problem?
