Temp gauge not working??
Start by checking the wire is still connected to the sending unit.
The sending unit is located on the drivers side of the lower intake manifold, toward the front of the engine.
jason
cool, thanks...I'll look there. this car I'm thinking about buying it is isn't working. Also the oil pressure drops down between the 1st and second mark at idle. Is a 1990 convertible 7-up edition...he wants 3500 for it.
If the oil pressure really is dipping that low at idle, then the motor may be ready for an overhaul.
The stock gauges are pretty unreliable though, especially oil press. and coolant temp.
$3500 for a 5.0 that doesn't run seems a little high.
Then again I am getting pretty cheap in my old age :shrug:
jason
I took it for a test drive and it ran pretty well. There was no smoke even at high rpms. I reved it just sitting there and had someone standing back there to see if there was smoke and there wasn't then either. So still considering
Low oil pressure would be due to worn cam or main bearings, and may not show in the exhaust.
Find out what grade oil he is using. If it is a thin oil then that may be the reason as well.
If it runs and doesn't smoke then it may be a good car?
I'd take it to a mechanic or see if he will let you take it home, and hook up a diagnostic oil pressure gauge and temp gauge. This will be quite revealing.
Good luck.
You can test the temp gauge by grounding out the wire. If it's working, it will peg the needle all the way. Most likely it's just a bad sending unit. Stock gauges suck ass anyway.
I second (or third) that the stock gauges suck! My oil pressure gauge has been dropping to zero when the RPM's go above 2000. I drop in new gauges (autometer) and the pressure stays at 50 psi until warm and idles at 40-45 psi. Either the gauges were crap or my sending unit needed to be replaced.
this is funny cause your talking about a oil pressure gauge your topic says temp gauge but yea i have to change mine also if your oil runs low or old your pressure will drop to as far as the temp gauge goes mine still dont work and its brand new
My oil pressure drops real low sometimes too, especially when it is warmed up. Sometimes it does, sometimes it doesn't. Sorta scares me, but it still runs great. I run 10w-30, always have, and change oil at 3k miles like it's religion. My motor has a 105k on it. Is it possible it's due for an overhaul?
It is funny, I almost laughed myself when I wrote it. Next time I'll be down to a nats butt and make sure I'll get every single subject in the title that might come up in a paragraph while I'm writing it. On second thought I can also just make two posts....you guys are wearing off on me I better stop. LOL Thanks for the reply.
