Engine Temperature reading is not working properly
ggradtech
179
18
28
My 351w engine has a temperature reading issue. Just today, it is spiking at 210, going down some, and going up again. It’s not accurate though. My fan probe activates the fans to come on at 180, and that is working perfectly. Could the temperature sending unit that is threaded into the upper intake be the culprit? I hope it’s this and not a wonky gauge in the dash panel. Thanks
From what I have seen, that is an indication of a low coolant level. Some of the other guys may want to chime in and give you some advice on burping the coolant system.
Reactions: 2000xp8
Good catch joe!
Do you have a coolant recovery tank?
Some use a Lisle funnel, I jack up the front of the car as high as I can when refilling the radiator, squeeze the lower hose as I fill it.
I’ll certainly check my coolant level. The thing is though, when the engine is not HOT, it reads like 210. It goes up a little and back down. The temp probe is a 180* one. The fan does come on at about what “seems like” it’s at 180ish or so. This is why I figure it may be something with the sending unit or possibly the gauge in the dash.
Just get an aftermarket gauge, you can mount it on the bottom of the dash or in the engine compartment even if just temporary.
you could get an infrared thermometer pretty cheap and compare readings. Compare it to the stock gauge readings.
Reactions: 90sickfox
The gauge is an aftermarket one. This morning it’s pretty cold out. I started driving and it stalled under 150 for a while, then went to 180 for a bit. Then, all of a sudden, it was bouncing between 180-250 and back and forth. Then it stayed at 250, so I immediately drove to my garage. I cycled the key a few times, but it stayed pretty hot. Maybe 230 or so. The fans were on as well, but they are triggered to go on at 180. Maybe once it’s cool again, I should run the motor until warm/hot with the radiator cap off to check and see that the water pump is cycling water through the radiator fins?
Sounds like I’ll remove it and replace the thermostat. It’s weird though that I just had my intake resealed last week and also a new t-stat housing installed. Maybe the new (assuming new) t-stat is bad?
What kind of fans are you using ? I use Ford Contour fans on my tubo fox with no issues...temp stays around 202....192 degree thermostat.
Same here. Contour fans. I only had this issue pop up in the last day or so. I did have my intake resealed recently. I’m gonna take some infrared gun readings too just to confirm it’s not a wonky gauge or sending unit.
@ggradtech
Testing the thermostat:
Buy a cooking thermometer from Walmart its about ~$10 or so; be sure that it goes over 200°. Put a pot of water on the stove and turn the heat on high. Put the thermostat and the thermometer in the pot; watch the thermostat open as the water heats up. If it isn't wide open by 210 °, you have a problem.
  • Useful
Reactions: General karthief
So I ran the car today. While cold, I uncapped the radiator and let it come up to temperature. Once it got decently warm, I noticed some big air bubble burps. I then recapped the radiator and took it for a few mile drive. So far, Im thinking it may have had some air trapped in the cooling system. Maybe the air pocket purge cured it?
When it spikes like that, it's most likely air in the system.
The thermostat isn't going to cause a spike, overheating, yes, but it doesn't open and close fast enough for you to instantly see it on a gauge.
