  • SN95 4.6L Mustang Tech
Tensioner pulley making tiny chirp?
  • Thread starter Thread starter 281CI96Coupe
  • Start date Start date Apr 1, 2007
281CI96Coupe
233
  • Apr 1, 2007
The tensioner pulley is making a tiny chirp/squeak...What can do to make it stop doing this because I dont want to sit on it and not do anything about. It doesnt do it all the time but when i get on it sometimes it does it? Any advice guys?
-Nate
RandyStinchcomb
1,159
Randallstown, Md
Apr 2, 2007
  • Apr 2, 2007
-Nate
put a new tensioner on it, esp if you have the old style tensioner wth the aluminum arm, which is prone to bending and causing belt squeal and other belt issues.
Ford has an improved tensioner that has a steel arm, part # XR3Z-6B209-DB and comes wth a new belt, pricey but worth it
T
TripleBlk
312
Cape Canaveral FL
Apr 2, 2007
  • Apr 2, 2007
Randy's info is spot on. I started with a little chirp, and ended with a fairly constant squeal, especially inder load. I knew it wasn't the belt because mine was really fresh.
The kit you can get (through Randy) has the steel tensioner arm and a new tensioner pulley attached (plus belt). Good stuff , and genuine factory parts, which work. I installed mine today. HTH
propellerhead
1,541
"but what's with the but shots?"
Apr 2, 2007
  • Apr 2, 2007
So how much is this kit to get rid of the chirp?
Chili
174
Euless, TX
Apr 2, 2007
  • Apr 2, 2007
My tensioner started grinding into my front cover at about 20k (you know, the 'quality' factory piece). I bought a replacement at Napa for $20 or $30 and have put on another 25k with no issues.
The way I discovered it was that my belt was slipping / squeaking. When I replaced the belt I was looking closer and saw the metal shavings.
RandyStinchcomb
1,159
Randallstown, Md
Apr 3, 2007
  • Apr 3, 2007
$138.00 + shipping for the 3 bolt tensioner, not to-be confussed wth the above 1 bolt tensioner spoken about above
Fog horn sound
  • brandon4v
  • Jun 22, 2026
SN95 4.6L Mustang Tech Jun 23, 2026
squeak93
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
