tensioner
  • Thread starter Thread starter mustangp89
  • Start date Start date Aug 6, 2007
M
mustangp89
  • Aug 6, 2007
I cannot figure out if the long bolt and nut must be removed to replace the tensioner on My 89 4 cyl mustang. Can't find the correct socket size, This bolt does have to come out, dosn't it? Please help!
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Aug 6, 2007
  • Aug 6, 2007
On my 93, the tensioner is mounted to the front of the engine using a bolt from the back. You may have to loosen the alternator bolts and slide it out of the way to get to it. Loosen the bolt and the whole tensioner assembly will come off. The pulley can be changed by itself if that is all you are needing to replace..
M
mustangp89
  • Aug 22, 2007
I can't find a proper sized socket to fit the nut at the rear of the bolt! Closest I got was 17 mil. Just seems a wee bit to loose and am afraid of rounding the nut out!
Probably has not been loosened since 89. :
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Aug 23, 2007
  • Aug 23, 2007
I've always used a standard socket to take off the tensioner nut but I can't remember the size.
I'm thinking 3/4-13/16, somewhere around that.
BTW, take off the distributor cap and rotor while you get at the nut, makes it a LOT easier.
Tensioner arm bolt
  • brandon4v
  • Jan 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
