tfi blaster coil
Makdaddymac
323
orlando
i installed one of those oem fit msd tfi blaster coils>.. Claims for better trottle response,and so on.And i must say im pretty impressed i do feel some(note SOME) change in the throttle response.Anyways im happy cause it was brand new and free.My uncle had it laying around for his bronco back in the day...anyways it kinda hums like a virgin bee;it not loud but it hums. Is that normal cause it is high performance in factory clothes or is something gonna go haywire..thanks
MSD coils are known for noise,I had an Accel super coil do the same.
I returned the Accel coil and bought a Moroso Pro Coil HO instead.
No noise with the Moroso coil,and Moroso claims their coil outperforms all the others.
A coil is is just a small electrical transformer and some humming is normal. Walk past a pad mount utility transformer and you can usually hear them hum and if you put you hand on it usually you can feel it. So some amount of humming should be considered normal.
If you can hear it humming above the engine and WOT then I would guess that there is a problem. :D
My buddy got one and used to hear it through is stereo...it was annoying. Turned out to be a burned boot on the spark wire and the signal was transmitting through that into the electrical system. Weird *****e :shrug:
