  • 1994 - 1995 Specific Tech
TFI Module and Stator Replacement for $850???
  • Thread starter Thread starter limppimp
  • Start date Start date Jun 26, 2007
L
limppimp
149
  • Jun 26, 2007
Well, my car would not start so I had it towed to the local Ford dealership. They told me that I needed a new TFI module and a stator. They want $850 for the work. I was thinking of buying the parts and doing it myself. I know the module will be easy to change but I am not sure about the stator. Is this a difficult change out? Also, what kind of module and stator should I get?
Any help is greatly appreciated.
C
Chris_Red_V8
95
Scottsdale, Az
Jun 26, 2007
  • Jun 26, 2007
holy crap.
The TFI module is under the maf on the passenger side (you can see it bolted to its heatsink), and the stator is inside the distributor.
What I did was just go to the parts store, buy a distributor with a lifetime warrantee and replace mine. I ended up buying a F150 one because it was taller overall and matched better with my intake setup.
The parts shouldn't run you more than $200, and install time is about 30 minutes.
L
limppimp
149
  • Jun 26, 2007
Yeah, I was wondering if I should just buy a whole new distributer to make the job easier. Thanks for the help!
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jun 26, 2007
  • Jun 26, 2007
Just get a new dist. I replaced mine in like 30 minutes and it was my first time ever swapping one.
As far as the TFI, doesnt that just plug to some wires and is screwed to the engine bay wall?
Guero
2,148
Jun 26, 2007
  • Jun 26, 2007
Talk about trying to rip you a new one......For that price you can upgrade your ignition system to good plated wires and a 24 karat distributer !!!
badstang123
397
Santa Clarita, CA
Jun 26, 2007
  • Jun 26, 2007
Exactly. For that price you could put in MSD everything from top to bottom for the ignition system.
- Justin
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 26, 2007
  • Jun 26, 2007
hoy hell thats waaaaay overpriced!!!
new tfi- ~40-50
new/reman dist ~100
timing light ~40
the satisfaction of doing it yourself... priceless
Pokageek
2,767
MA, USA
Jun 26, 2007
  • Jun 26, 2007
THE ARE RIPPING YOU OFF
L
limppimp
149
  • Jun 26, 2007
Yep, sounds like I will be doing it myself. Thanks for the info guys!
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Jun 26, 2007
#10
  • Jun 26, 2007
  • #10
Wholly ****!
94_Teal_GT
405
Palm Bay, FL
Jun 26, 2007
#11
  • Jun 26, 2007
  • #11
Take the TFI module to Autozone, just to see if it's actually bad, they can test it for you and will let you watch. You would need a press to remove the distributor gear in order to fully disassemble the distributor to replace the stator. It's far easier to just swap out the distributor.
C
chuck943
262
north carolina
Jun 26, 2007
#12
  • Jun 26, 2007
  • #12
They must be having a bad month!!
HISSIN50
34
129
Jun 26, 2007
#13
  • Jun 26, 2007
  • #13
Did you remember to ask them to convert that dollar amount from Martian dollars to USD?
The Green GT
1,269
Louisiana
Jun 26, 2007
#14
  • Jun 26, 2007
  • #14
Man, for that much money they better swallow.
L
limppimp
149
#15
  • Jun 27, 2007
  • #15
LMAO!
C
chuck943
262
north carolina
Jun 27, 2007
#16
  • Jun 27, 2007
  • #16
Man the techs must get paid real good there!! Price on parts from ford is only $213
Are you sure there isn't something else involved here? Thats over $600 labor,even if you live in the most expensive area in the country thats still 6 hours or more labor charges. Is the problem intermitant and he had to run a bunch of diagnostics to find it? I just can't believe that someone would think a customer is that gullible.
L
limppimp
149
#17
  • Jun 27, 2007
  • #17
I just got it towed back to my apartment.
The only thing the mechanic told me was it needed a module and a stator...he didn't say anything else. Mabye the labor comes from the stator change? Then you have to add $90 just for the diagnostics.
69clark
731
Ravena, NY
Jun 27, 2007
#18
  • Jun 27, 2007
  • #18
Ford dealers have always pissed me off. If they don't have their nose in the air than its crap like this.
C
chuck943
262
north carolina
Jun 27, 2007
#19
  • Jun 27, 2007
  • #19
yes but stator replacement is pretty easy 30 minutes tops. I would have asked to explain the labor charges, but since you had it towed away probably best just to forget it.
good luck
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
C
Electrical Multiple spark with spout in, normal when out
  • Cumstang59
  • Dec 28, 2024
2K
1994 - 1995 Specific Tech Feb 5, 2025
Cumstang59
C
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
