TFS head question...
I recently purchased a new pair of TW heads with the intention of using a Stage 1 camshaft, but have since decided to step up to a Stage 2 unit instead. I understand that my current valve springs will not tolerate the lift of the Stage 2 camshaft and an upgrade is required to avoid valve float. Can I use any brand of valve spring with a sufficient rate or am I limited to TFS brand springs because of the head's configuration?
Ted Bell
Guys....keep in mind that lift is not the issue with PtV problems...when the valve is fully opened during the int/exh cycles, the piston is at the bottom,.... the cam overlap (OVL) time period is what you have to watch out for.
I'm running 289 '66 heads with a lift in the .576" zone, no modifications to the heads, aside from the proper spring/retainer combo. I had to notch pistons due to the X303 OVL spec (62° over the OEM's 39°). The stg 1, having an overlap of 66°, does require a PtV check to be on the safe side, even with TW heads. My 2¢.
Mike92GT said:
Hopefully this isn't going on a stock short block, or you will have piston to valve clearance issues
No, the shortblock has relieved pistons. However, I've read and heard of a lot of folks that have used TW heads and Stage 2 camshafts on stock shortblocks with no clearance issues. Do a search, there's a lot of them.
Ted Bell
