TFS highport heads Probably buying some
mytight95
2,605
Dothan,Al
I have the chance to buy some of the tfs highports, they are the old cast iron ones, no porting or anything, my question is has anyone dynoed any kind of setup with these heads, and if so what intake and such did they use to flow as well as the heads, and also what kind of cam would you need.
Jason
I think these are pretty similar to the aluminum version and lots of people used the old aluminum high ports when there were not so many cylinder head choices out there. I know that you will need different headers because of the raised exhaust port.
I base this guess on an old Will Burt add which mentioned high port heads in iron or aluminum. That sounds like they would be almost identical besides the material.
The one set of old school high ports that I have seen had huge ports, but I think they had been ported pretty extensively.
Good luck and tell us what happens.
