TFS or Holley?
hazmatpony
Just want to get some general thoughts here. What do you guys think would be better, TFS or Holley top end kit? I am building up a 347 stroker and want to get the best bang for the buck (I'm not poor, but I'm not Bill Gates). I have looked at just about every combo out there, as I am not that savvy with all the technical stuff, just looking for some thoughts on what H/C/I combo you would run if building a stroker. Just to clarify, I have no intention of ever running nitrous or s/c, just want a nice, streetable stroker, I have a friend that is running edelbrock performer heads and intake and it rips a$$, but I don't want to copy his setup.
Neither. Piece together a kit.
A proven 400+rwhp combo would be afr 185's, anderson N91 cam with valve springs, holley/tfs R/victor intake, 75mm tb minimum, 30-42lb injectors, 1 3/4" longtubes, 3" mid pipe.
I personally run an 11:1 347 with twisted wedge heads, tfs R manifold, fti custom cam, 1 3/4" longtubes. It needs a 3" mid pipe and it should do around 400rwhp or close to it.
Sidenote - An Accufab 65 or 70mm throttle body would be PLENTY for 400rwhp. It flows way more cfm than a 347 can even think about pulling in...
Holley Systemax Intake/AFR 185/FTI Cam/1.6 RR's/Matching pushrods, measured/Good 65 or 70mm Throttle Body, a 75 is just wasting your money/30 or 36lb injectors with matching MAF (Mass Air Flow Sensor).
1 5/8 or 1 3/4" exhaust, depending on valve timing of your cam. A catless H pipe of 2.5" works wonders and flows well into the 5-600hp range, so your good there.
If you are set on getting one of the kits that are pieced together, I'd go with the TW's (Track Heat heads/Track Heat Intake). Good portability on the heads and proven to put down nice numbers. The systemax kit has a very nice intake, but the heads and cam are lacking.
Performer is better than both, look at the attached chart
