I aquired a long block 5.0 that consists of a never run 4.00 bore block, '86 flat top pistons, B-cam and TFS T/W heads. This was put together 5+ years ago and never ran.
This motor was "built" with the old rings, t/c, and I believe even the oil pump from the 86! Though it does have new bearings and ARP rod bolts. Anyway, I am going to reassemble this with new parts, Z cam (have one), and fit dome pistons that are compatible with the twisted wedge's unique wedge chamber and valve angle - however I cannot find std. size pistons!
Question 1. Is anyone aware of std. dome pistons for the TFS application?
Question 2. Failing no 1. I will more than likely use the flat top pisons, who makes a good notch cutter?
Thanks in advance!
Thanks in advance!
