TFS STAGE 1 CAM INSTALL
  • Thread starter Thread starter 91 lx hatch
  • Start date Start date Jun 12, 2007
91 lx hatch
11
  • Jun 12, 2007
Can i install the tfs stage1 cam without getting new springs and will it clear the stock pistons.i have the stock longblock with a b303 cam how much better would the tfs stage 1 cam be over the b303
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 12, 2007
  • Jun 12, 2007
It should clear. I had a friend running an F303 cam with some iron GT40's (1.90 intake valve) and that thing's got .512 lift on both the intake and exhaust. The TFS-1 is .499/.510 I/E, so I don't see why it wouldn't. The F cam is about the maximum recommended lift on stock pistons with inline valves from what I've read.
V
v8only
2,378
22
49
Jun 12, 2007
  • Jun 12, 2007
the tfs 1 cam will clear without issues, my bro runs one with 1.6 rr's, and I'll be running one VERY soon (have already bought it, just need to install it)
fyi, don't run 1.7 rrs, or you could have interference.
I wouldn't run stock valve springs, especially if they have miles on them. the tfs valve spring kit is what I went with from summit, and they're VERY cheap, at around $100ish
D
Deleted member 87397
Jun 12, 2007
  • Jun 12, 2007
If you already have a b cam i don't know that you'll see much of a diff.
2000xp8
SN Certified Technician
Aug 8, 2003
8,076
1,659
194
NJ
Jun 12, 2007
  • Jun 12, 2007
Changing the cam on a stock headed car isn't worth the time or the money.
Use some 1.7 roller rockers instead, until you are ready to do the heads.
What you are considering would be a waste of perfectly good gaskets and anti freeze.
ls1beater4eva
334
mooresville
Jun 12, 2007
  • Jun 12, 2007
you can run 1.7 rrs on the tfs 1 cam with no pvc issues i have one in my best friends car rite now with some gt 40 heads and a gt40 intakek with some 24s and the car runs awsome. i would change the valve springs either way.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
