Hey anyone know which cam would pull stronger at low end take off... TFS stage 1 or F303 cam? The heads that are ebing used are TFS twisted wedge and the stang is a 3 speed automatic, with 3:25 gears and a 2800 stall convertor. This means I'd be taking off the line at 2800, the F cam has lift of .512/.512 and duration of 226/226, making peak hp at 6000rpm and peak torque at 2800 rpm. The TFS stage 1 cam has 221/225 duration and lift at .499/.510, peak hp at 5500rpm and torque at 2000 rpm. Which cam sounds best for low-mid range for my setup and drivetrain?
