These are the 3 stages for the custom chip..
WH1: Idle is set to 850 rpm, rev limiter is set to 6800 rpm, fans on @ 185 degrees, removed speed limiters and shift retards, wide open throttle fuel is 2% leaner than stock, and total timing is set to 30 degrees.
WH2: same as WH1 only total timing is set to 31 degrees and WOT fuel is stock.
WH3: same as WH1 only total timing is set to 31 degrees and WOT fuel is 2% richer than stock.
Lemme know what you guys think.
