The Dynamic Duo Strikes Again
  • Thread starter Thread starter xj220
  • Start date Start date Aug 5, 2005
xj220
696
Aug 5, 2005
  • Aug 5, 2005
Well after searching and finally getting the parts to the shop and having everything worked on, the car is now fixed. Turns out the heat from the headers caused the master and slave cylinders to break down. To counter this, the shop wrapped the left header near the cylinders (not the whole header, just part of it). I know wrapping headers isn't adviseable, but I'd rather have to replace them much farther down the road as opposed to buying new master and slave cylinders every couple years. The car runs great now and everything was going alright on the way home when all of a sudden the engine starts to die. At that point I remembered that the cylinders crapped out on me on the way to the gas station. Luckily, we had some gas at home and it was easy enough to take care of. That's good enough excitement for me for the whole summer. At least the car is fixed now.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Aug 5, 2005
  • Aug 5, 2005
Good to know!
You can also wrap your master and slave cylinders in some heat shielding to further protect it from the elements.
10secgoal
2,801
San Diego
Aug 5, 2005
  • Aug 5, 2005
70_Nitrous_Eater said:
Good to know!
Think that would be the better way to go. Definetly. Then, you don't have to buy new headers, or rack/master cyl.
See, we can agree Nitrous.
F
ForceFed70
4,818
BC Canada
Aug 6, 2005
  • Aug 6, 2005
Maybe... you think the heat shielding should be tinted blue?
Route666
1,652
Brisbane, Australia
Aug 6, 2005
  • Aug 6, 2005
Hell no, it will absorb more heat that a yellow or white would...
F
ForceFed70
4,818
BC Canada
Aug 6, 2005
  • Aug 6, 2005
Nonno... blue is so much cooler! Tho maybe a metalic-blue would be best.
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
