- Oct 21, 2006
- 525
- 43
- 49
The below is from an article I read.
Nitrous or Supercharging Without Proper Planning
Nitrous and supercharging can be costly mistakes if you don't do your homework beforehand. If you're contemplating quick, cheap power gains (nitrous-oxide injection), you must first know what's inside your engine. Cast or forged aluminum pistons? Cast pistons? Forget it. Forged? Good-you are cleared to proceed to the next step. What is your engine's compression? Don't know? Then you better check now.
When manufacturers assure you 100, 150, 200 bolt-on horsepower increases by touching a button, sacrifices will be made elsewhere. Your engine will not live as long. Nitrous introduces your engine to a violent jolt of extreme heat energy hammering the piston crowns, rings, and lands. Rod bearings also take a pounding with nitrous.
The same rules apply to supercharging, which isn't quick, nor is it cheap. It's just more subtle than nitrous, and mandates special care. Remember, there are no free lunches in the world of power. When you gain big one way, you make huge sacrifices somewhere else.
So, does this mean if I was to run a Zex dry nitrous kit, with a 125hp shot, that I would be shortening the life of my motor?
All the nitrous companies state in their FAQ's, that if you run the amount of nitrous that your set-up can handle, it will not shorten the life of your motor.
Is it not a good idea to run the Zex kit with my set-up?
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Holley 190 lph Fuel Pump /
Thanks
