The Fast and Furious Mustang glowing gauges
plastic_cow said:
Not to mention that on the 90-93 stangs the tach has the engine warning lights under the tach, but in the F&F gauges they just cut out holes under the tach to make room for the warning lights - instead of the APC gauges that have just the warning part cut out (for example, check engine is cut out, with the little logo, not some ugly-a$$ square...)
Grrr...
Mustang, the anti-rice
they dont use an external source, you wire them into your headlight switch, works as normal, has dimmer, everything. I used a bezel, and the cut outs look complete normal and stock. The real issue is it a quality product, it illuminates very well and is easy to read and tasteful. The different between these gauges and the stock ones are the color and some better technology, that is it. Bulbs that go out behind your gauges SUCK, there is nothing good about them.
