  • 1994 - 1995 Specific Tech
the infamous swap
  • Thread starter Thread starter chief44
  • Start date Start date Feb 3, 2008
C
chief44
50
Western PA
Feb 3, 2008
  • Feb 3, 2008
My son bought a 94 6 cylinder when he turned 16. Now after two years, he wants to swap the 6 for a 5.0. I'm sure it has been discussed here a million times, but can u guys point us in the right direction for what we need to do. We already picked up a 5.0 engine out of a 90 gt that was an automatic car. it will be going in with a 5 speed. Any help would be great.
onlyme
375
missouri
Feb 3, 2008
  • Feb 3, 2008
www.sorscode.com that should help
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Feb 4, 2008
  • Feb 4, 2008
Get a donor car. Look out for a wrecked 94-95 Mustang. Then just swap the drivetrain. You'll get the rear end and everything else needed.
Or as cheap as the 94-95 5.0L's are getting, sell the v6 and buy a GT.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Feb 4, 2008
  • Feb 4, 2008
I second that. You'll save thousands of dollars that way.
Kurt
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Feb 4, 2008
  • Feb 4, 2008
Kurt
I third that. I'm doing such a swap now, and it's a HUGE PITA. There are two reasons why I'm doing the swap:
1. My Grandfather helped me buy my 94 V6, the stang is a cherished memory of him.
2. I want the experience, to learn how to do it, and to be able to say, "I did this."
I only have weekends to do the work - I started in November, and I'm still not done. Granted, I'm doing a lot of work that isn't necessary, but I want it done. My signature has a link to my progress thread, check it out.
Dagz
173
Quesnel Canada
Feb 4, 2008
  • Feb 4, 2008
I did the swap a few years ago, here is the low down. If the car is a 5 speed now you can use it same with the dive shaft and cross member, however the clutch, flywheel, throughout bearing and bell housing are all different. You will need a complete injector wiring harness and pcm harness aswell as the pcm it self. the computer you want is the tm40. The front cover on the 90 5.0 is different than the 94 95. It is longer and has some different belt routing. The water pumps spin in the opposite direction. You can use the 90 front cover but it is a little longer and will come close to the rad. the rad and fan you can use but you will need a new fan speed motor as the v6 one will cause the car to heat up. I would recommend using a 95 upper intake and either 86-93 or 94/95 lower will work.(the ealier models flow better). the reason for the upper intake is less work now or you better do a search on a fox throttle body conversion if you want to use the upper you have. I will not go into this because it is covered when you search the forums. The V6 k member will work and I used 94/95 motor mounts not sure whatelse will work. you will need 94/95 fuel lines, fuel rails, tab tad and egr sensors if you paln on using egr and smog. A 5.0 throttle cable also 94/95 and 94/95 headers so they line up with the egr. i recommond keeping the egr as our computers need a tweecer to eliminate it properly. i think that cover most of it if you need any help please email me I have pics of the swap.
W_dagenais@hotmail.com I also have most of the parts you are looking for but I am located in Canada Good luck it's a great swap and a good learning experience.
J
jefferz
110
Spokane, WA
Feb 4, 2008
  • Feb 4, 2008
I did the swap about a year and a half ago. The best option is to find a wrecked 94-95 GT and swap everything over. Thats what I did. It runs great!
J
jefferz
110
Spokane, WA
Feb 4, 2008
  • Feb 4, 2008
Also, like what was said above...use Sorscode.com. It helps a lot!
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
