the lil black thing with the wire comming out the back of the steering wheel that....
140CILX-Coupe
189
connected to the auto shifter.....does it mean anything if that was removed?
fly and pp torque #'s are what again?
and the wire by wire for the trans.
the plug on my trans has a wire going from one to the other(like bridged looks like on an amp) and 2 lower wires are seperate.
Just stuff
Th first item is a devise that locks the key unless the shifter is in park..not needed for the T-5. The looped wire is (I believe) for the neutral safety switch.
This function is now handled by a switch on your clutch pedal. In doing the pedal swap you will find a similar plug under the dash with a looped plug in it. just remove the plug and plug the wire into the switch on the clutch pedal.
The other wires on the tranny are for the backup lights.
Bruce
