The same old Dual Master Cylinder Question...
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
I want to replace my Single Master Cylinder to Dual. I have a stock V8 65 still with 4 wheel drums. From what year will work? I do plan on replacing ALL the break lines as well.
Thanks for you help.
(I did search but couldn't find the answer. :shrug: )
when i did this swap on my 64 falcon, used the same fruit jar master cylinder as the mustang does, i used a 67 mustang drum brake master cylinder. as for the brake lines contact Classic Tube - PreBent and Custom Stainless and OE Brake Lines and more... or Inline Tube - Preformed Stainless & OEM Brake Line Sets for new brake lines already bent up and ready to install. i didnt replace the brake tubes though, i just used some short sections you can find in the parts store as well as some brass fittings and couplers for the conversion. it should only take you about an hour or two to do the job.
